Realistic super tweeter?
A longtime friend of mine was a longtime Radio Shack guy and I remember hearing these sitting atop Mach 1's, at point blank rage (a typo I'll leave) with however much power the big silver Realistic receiver made, about 120 I think. I'll give it a 9+ on volume and a 7- on sound quality.
I do think those supertweeters were pretty good. RS had them crossed over at 5kHz. I wonder how low they can go.
Those speakers are pretty nifty. I have some wired inline with a separate volume control because they're so loud compared to my other speakers.
The floor standers are aperiodic vented, I used a resistor to balance them with the rest of the system. I could improve on the x over but then again they are my beat on knock the house down speakers. Super efficient too
So, in 2012 it was decided all these need is a 4.7uF cap "bypassed" with a 2.2uF cap? If using a decent quality M.P. cap why "bypass" with a small value cap? No inductor? No L Pad?. I know, this post is ancient but I recall these did sound pretty good and I got a set. Was thinking of trying them out. Maybe I will make a easy to access board of some kind and play with values... I do want to sit them on top of my other speakers because I would like to be able to move them front to back and mine have no enclosure....yet. Any comments would be appreciated! Thanks!!
i used some pvc pipe to try to keep the original look. eventually glued them to some plywood for the base.
in use to this day.
@orsen that is not a bad idea at all. I also thought being that I am so profoundly good at wood working (yeah right) that I might cut to pieces of wood. One with a hole and one for a base and mount them that way. May well try the PVC first. I kind of like to experiment. What are you using as a crossover? Also, I noticed you have a set of Energy Veritas. I actually have a set too however on woofer is missing in one of the cabinets. I did hook them up and listen to the Mid and Tweet only with a small subwoofer just to get an idea of how they sound well, basically to see if the worked well. I liked what I heard even though it was not an optimal arrangement. I would have liked to listen to them of course with both woofers but just about impossible to find them now. Only used ones I found people seem to be a bit "proud of them".
