Recapping a Yamaha PX-3 linear tracking turntable
So, the recapping list was simply all the electrolytics and the one safety cap. I replaced the diodes with the odd oxidization, just to be safe.
Detailed spreadsheet:
Board Component number Qty Type Sub-type Value 1 Value 2 Value 3 Part number Notes Mouser PN
Control D30 1 Bridge Rectifier 1D4B1 (bridge) 583-W04M
Control C32 1 Capacitor Electrolytic 0.47 uF 50 V power 647-UPW2CR47MED
Control C19 1 Capacitor Electrolytic 1 uF 50 V power 647-UPW2C010MED
Control C6,C18 2 Capacitor Electrolytic 10 uF 35 V power 647-UPW1V100MDD
Control C13 1 Capacitor Electrolytic 100 uF 35 V power 647-UPW1V101MPD1TD
Control C12,C28,C29 3 Capacitor Electrolytic 1000 uF 35 V power 647-UPW1V102MHD
Control C21,C22,C23 3 Capacitor Electrolytic 22 uF 16 V power 647-UPW1C220MDD6TP
Control C14 1 Capacitor Electrolytic 22 uF 50 V power 647-UPW1H220MDD
Control C15 1 Capacitor Electrolytic 220 uF 50 V power 647-UPW1H220MDD
Control C7 1 Capacitor Electrolytic 33 uF 16 V power 647-UPW1C330MDD
Control C24,C25 2 Capacitor Electrolytic 470 uF 35 V power 647-UPW1V471MPD
Control D12 1 Diode ??? B03W
Control D1,D2,D5,D6,D7,D8,D9,D10,D11,D15,D16,D17,D18,D19,D20,D21,D22,D23,D24,D25,D26,D27,D31,D32 24 Diode General purpose, switching, power 1N4148 1S1555 512-1N4148
Control D13,D14,D28,D29 4 Diode Rectifier 50 V 1 A W03B 512-UF4001
Control D12,D3,D4,D33,D34 4 Diode Rectifier 50 V 1 A 1S1555 512-UF4001
Control ZD1,ZD2 2 Diode Zener 6.1 V 0.5 W WZ061 512-1N5234B
Motor unit C1,C2,C3,C4,C6,C21 6 Capacitor Electrolytic 10 uF 35 V power 647-UPW1V100MDD
Motor unit C5 1 Capacitor Electrolytic 22 uF 35 V power 647-UPW1V220MDD1TD
Motor unit C9 1 Capacitor Electrolytic 4.7 uF 25 V power 647-UPW1E4R7MDD1TD
Motor unit C23,C24 2 Capacitor Non-polarized Electrolytic 33 uF 25 V power 647-UVP1V330MPD
Power Supply C34 1 Capacitor Safety Film 0.022 uF 125 VAC 275 VAC Y1 300 VAC X1 PME256MB522 0.022 uF 125 VAC 275 VAC Y1 300 VAC X1 film safety cap 80-PME271E522MR30
Cut-and-paste BOM (for Mouser.com):
647-UPW1C220MDD6TP 3
647-UPW1C330MDD 1
647-UPW1E4R7MDD1TD 1
647-UPW1H220MDD 2
647-UPW1V100MDD 8
647-UPW1V101MPD1TD 1
647-UPW1V102MHD 3
647-UPW1V220MDD1TD 1
647-UPW1V471MPD 2
647-UPW2C010MED 1
647-UPW2CR47MED 1
647-UVP1V330MPD 2
80-PME271E522MR30 1
(and if you want to replace the diodes with the oxidization)
512-1N4148 24
Oh noo, duplicate entry. Ordered and 220uF was nowhere to be found... this is why.
---->Control C15 1 Capacitor Electrolytic 220 uF 50 V power 647-UPW1H220MDD...
same as
same as
Dang! sorry about that and thanks for catching it. I’ll update the prior posting.
N/P glad I found it.
Also here are modern equivalents for the transistors:
2SC2320 -> 512-KSC1815Y
2SD667 -> 512-KSC2383Y
2SB647 -> 512-KSA1013Y
2SA999 -> 512-KSA1015Y
(Thank you Ty!)
Btw, ever seen a PX-3 that has an issue with the LD101 inside the arm that does not light up fully? Because of that it does not track.
See video here:
Led is physically ok but the circuit supplying power to it seems to have a problem. What a PITA!
@RCHeliz, when you get to the bottom of it, post what you found. We can use @dlucy's post to keep all of the electrical gremlins in one spot. That is the first that I ever heard of that issue.
Thanks
BillWojo
2SC2320 -> 512-KSC1815YTA
2SD667 -> 512-KSC2383YTA
2SB647 -> 512-KSA1013YTA
2SA999 -> 512-KSA1015YTA
Glad you posted a list. If you would, please edit it and remove the “TA” from the end of the replacement devices. Those two letters are not part of the replacement part number; they are the packaging type (e.g. cut tape, bulk, ammo pack, reel, etc). If someone is looking up replacements, you don’t want them to think the part isn’t available when it’s just that part in THAT particular packaging type is out of stock. A lesson I learned the hard way.... ;)
Also wanted to add the led that drives the arm tracking.
Also on that list there are some 160v caps which are really not needed at that high of a voltage rating.
Not that they would not work in the circuit just no point to have 160v rating.
Arm LED - NTE3000
Table has been repaired see the initial thread for details.
Detailed spreadsheet (edited 3/4/2020):
Control C15 1 Capacitor Electrolytic 220 uF 50 V power 647-UPW1H221MPD
Cut-and-paste BOM (for Mouser.com) (edited 3/5/2020):
647-UPW1C330MDD 1
647-UPW1H220MDD 1
647-UPW1H221MPD 1
647-UPW1V100MDD 8
647-UPW1V102MHD 3
647-UPW1V471MPD 2
647-UPW2C010MED 1
647-UPW2CR47MED 1
647-UVP1V330MPD 2
80-PME271E522MR30 1
512-1N4148 24
Cut-and-paste BOM (for Mouser.com) (edited 12/16/2024):
647-UPW1C330MDD 1
647-UPW1H220MDD 1
647-UPW1H221MPD 1
647-UPW1V100MDD 8
647-UPW1V102MHD 3
647-UPW1V471MPD 2
647-UPW2C010MED 1
647-UPW2CR47MED 1
647-UVP1V330MPD 2
80-PME271E522MR30 1
80-R413I2220JB00M 1
647-UBT1H220MPD8TD 2
647-UKL1C220MDDANA 3
647-UPW1C330MDD 1
647-UPW1H220MDD 1
647-UPW1H221MPD 1
647-UPW1V100MDD 8
647-UPW1V102MHD 3
647-UPW1V471MPD 2
647-UPW2C010MED 1
647-UPW2CR47MED 1
647-UVP1V330MPD 2
80-PME271E522MR30 1
80-R413I2220JB00M 1
I just went to the Mouser site and the very first item on the list did not show as available......once I realized that this was not cut and paste, in that one has to remove the "3" at the end of the string, the item DID display but Mouser says:
Lifecycle:
End of Life: Scheduled for obsolescence and will be discontinued by the manufacturer.
and.....
Shipping Alert:
Mouser does not presently sell this product in your region.
So, what can one do to actually obtain the necessary parts to do this recap? Thanks.
You don’t need to stick to this list. You can use almost any capacitor with the same value and equal or higher voltage. So, if you cannot find Nichicon then take Panasonic or similar.
And, it is not necessary to exchange the diodes mentioned before, just because their legs show superficial corrosion. After cleaning with an eraser pen they look like new. The RIFA cap is the spark killer for the power button.
I agree with Dr. Ear, and if Mouser does not ship to you, you can use the following stores:
DigiKey
rs-online.com
Newark
Jameco
or
Farnell
(there may be more, I just post here what I used)
Regarding "End of Life: Scheduled for obsolescence and will be discontinued by the manufacturer." Any passive component with that message is still OK for our purposes here.
Thank you both very much. I really need to get off my duff and do this work. I can handle the mechanics, have developed my soldering skills, but really don't understand the electronics much at all. Yes, I can read what it says on the side of the capacitor, but do I really understand it? Nope, so a list that gives everything needed really is a godsend for me and I can probably run with that ball.....
In the service manual there is a list of all capacitors. Just try to find caps with the same specifications (same capacity, voltage can be higher, and 105 C, if possible). Hey, in a turntable this is by far not as critical as it would be in an amplifier.
Hi @dlucy and happy holidays. In post #23 you mentioned that you would go back and update the list in post #6. Can you please confirm that the list was indeed updated as I've got my cart all populated at Mouser waiting to order once I get that confirmation. Thank you very kindly.
Yes, I did... but, as always with shared BOM lists, you should double check the items before you order. Do you have two 220uF caps? Or one 220uF and one 22uF?
If you are talking about the C14 and C15 positions, I have one 220uF and one 22uF cap.
PS - thanks for getting back to me and helping out, of which I need a LOT as I know next to nothing about these things but am good at the mechanical end of it (soldering etc.).
The safety cap was one that I've seen fail (or, more likely, do it's job and die under the correct circumstances) and this particular cap looked a little cracky....
View attachment 1644248 View attachment 1644249
That type of capacitor needs special IEC or CE or UL safety approvals in order to be allowed placement across an AC power line. The approvals usually assure that if the cap fails, it will not start a fire. A coupling cap in an amplifier would not require this kind of rating. I did work testing other components for the same reason, and the test involved placing cheese cloth around the test part, and then subjecting the part to a prescribed overload condition. To pass, the part was not allowed to char the cheese cloth.
Thanks for going out of your way to provide this info. I own a PX2 which probably has the same caps. I don't use it much but when I have some extra time I would like to take care of it.
The electronics on the PX-2 are much different. It has another board and there are two power transformers!
Nevertheless, it is also easy to work on.
Dang! Using the BOM tool at Mouser, I am finding that 9 of the 14 components are listed with a red ! and the explanation is that they are no longer being produced or that Mouser is no longer selling this product. I'm starting to get the feeling that I'm not destined to do this project, much as I would like to, even got the table on my bench and got it all apart.....Here's the list I copied and pasted into the BOM tool:
647-UPW1C220MDD6TP 3 !
647-UPW1C330MDD 1 !
647-UPW1E4R7MDD1TD 1 !
647-UPW1H220MDD 1 !
647-UPW1H221MPD 1
647-UPW1V100MDD 8 !
647-UPW1V102MHD 3
647-UPW1V220MDD1TD 1 !
647-UPW1V471MPD 2
647-UPW2C010MED 1 !
647-UPW2CR47MED 1 !
647-UVP1V330MPD 2
80-PME271E522MR30 1 !
So, I'm guessing I'm out of luck here and will just pack it back up and use the functions that do work, although I'm pretty concerned about the wrong voltages getting to the chip and blowing that up......might just be a cool-looking paperweight on the other hand. I'm really not savvy enough to go searching for replacement components online to get the ones Mouser doesn't sell any more, so that list was, I thought, my holy grail of tools to use to get what I needed to replace.....dang!
