Recapping a Yamaha PX-3 linear tracking turntable
Dang! Using the BOM tool at Mouser, I am finding that 9 of the 14 components are listed with a red ! and the explanation is that they are no longer being produced or that Mouser is no longer selling this product. I'm starting to get the feeling that I'm not destined to do this project, much as I would like to, even got the table on my bench and got it all apart.....Here's the list I copied and pasted into the BOM tool:
This is where you have to decide if taking the work that was done to produce the original BOM and the work going into making that BOM (which was also shared) and now adding your effort to take the latter and look up equivalent, currently-available parts is worth it... or just leave the unit as-is. Below I've bolded everything you need to take the next step on your own:
Board Component number Qty Type Sub-type Value 1 Value 2 Value 3 Part number Notes Mouser PN
Control D30 1 Bridge Rectifier 1D4B1 (bridge) 583-W04M
Control C32 1 Capacitor Electrolytic 0.47 uF 50 V power 647-UPW2CR47MED
Control C19 1 Capacitor Electrolytic 1 uF 50 V power 647-UPW2C010MED
Control C6,C18 2 Capacitor Electrolytic 10 uF 35 V power 647-UPW1V100MDD
Control C13 1 Capacitor Electrolytic 100 uF 35 V power 647-UPW1V101MPD1TD
Control C12,C28,C29 3 Capacitor Electrolytic 1000 uF 35 V power 647-UPW1V102MHD
Control C21,C22,C23 3 Capacitor Electrolytic 22 uF 16 V power 647-UPW1C220MDD6TP
Control C14 1 Capacitor Electrolytic 22 uF 50 V power 647-UPW1H220MDD
Control C15 1 Capacitor Electrolytic 220 uF 50 V power 647-UPW1H221MPD
Control C7 1 Capacitor Electrolytic 33 uF 16 V power 647-UPW1C330MDD
Control C24,C25 2 Capacitor Electrolytic 470 uF 35 V power 647-UPW1V471MPD
Control D12 1 Diode ??? B03W
Control D1,D2,D5,D6,D7,D8,D9,D10,D11,D15,D16,D17,D18,D19,D20,D21,D22,D23,D24,D25,D26,D27,D31,D32 24 Diode General purpose, switching, power 1N4148 1S1555 512-1N4148
Control D13,D14,D28,D29 4 Diode Rectifier 50 V 1 A W03B 512-UF4001
Control D12,D3,D4,D33,D34 4 Diode Rectifier 50 V 1 A 1S1555 512-UF4001
Control ZD1,ZD2 2 Diode Zener 6.1 V 0.5 W WZ061 512-1N5234B
Motor unit C1,C2,C3,C4,C6,C21 6 Capacitor Electrolytic 10 uF 35 V power 647-UPW1V100MDD
Motor unit C5 1 Capacitor Electrolytic 22 uF 35 V power 647-UPW1V220MDD1TD
Motor unit C9 1 Capacitor Electrolytic 4.7 uF 25 V power 647-UPW1E4R7MDD1TD
Motor unit C23,C24 2 Capacitor Non-polarized Electrolytic 33 uF 25 V power 647-UVP1V330MPD
Power Supply C34 1 Capacitor Safety Film 0.022 uF 125 VAC 275 VAC Y1 300 VAC X1 PME256MB522 0.022 uF 125 VAC 275 VAC Y1 300 VAC X1 film safety cap 80-PME271E522MR30
Much appreciated, @dlucy, I will do a Google search for the bolded items and see if I can come up with what I need. I'm not at all unwilling to do the work required, but hampered severely by having zero understanding of such things. As I mentioned before, I can do the work and once I have the parts there should be no problem.
Thank you most kindly for taking the time to help me out, sir.
PS - .....and no, based on your opening comments in post #1 and @BillWojo remarks in post #13, I don't think it's a good idea to "leave the unit as-is." I've done some research since I posted this on the Mouser site and believe I've found the replacements for the ones that are out of stock. I'll call Mouser on Monday and speak with a tech to make sure the parts I selected as replacements will do the job.
I've fished a lot of tough rivers, waded into places that I probably shouldn't have, and stayed out way past dark when I could only put one foot in front of the other and feel my way back to shore. All of that was possible because I know rivers......this stuff......I don't have a clue and am thankful that there are folks on AK that will help me find my way. Like someone on here is known to say (@hjames) ......"after all, we're just walking each other home."
Thanks again......carry on amigo
