I stupidly didn't take photos of the underside of any of the boards on my unit and now have an issue. Can anyone explain what this ground(?) wire and cap is for and where it is supposed to go? The side that is connected is on the tuner board. Thanks again for bearing with my beginner struggles everyone.
Not sure if this is common or a one-off, but when I was rebuilding the phono board I noticed that resistors R103 and R104 were 4.7k ohms and not 330 ohms as in the design. I am wondering if this was an intentional change in the factory or an error. Any ideas?
I ended up switching it for the specced 330 ohms and everything is sounding great, so IDK.
Thank you @dlucy for the amazing guide. I would never have picked up this gem of a receiver had you not made this guide. Saved a ton of work and research!
You have eagle eyes! I was taking the caps off the P/S and was going to rely on the orientation per the service manual. If it wasn't that I came to this thread today and looked at dlucy's restoration, I would've installed the 47uF cap C602 incorrectly! Thank you to both of you!We need to address an issue with the service manual for the HK330c. The board layout shows that C601 and C602 are installed opposite to each other, one ground toward the left and one toward the right side of the unit.
You, @dlucy, have a pic of a recapped PS board above showing the two small caps behind the large caps with the negative side pointing the same way. I just did my power supply early this morning and mine are the same and I believe I installed them exactly as removed.
Since this is your thread, I'll let you have the credit but with that you need to update your 330c encyclopedic knowledge base and spread the word as to the correct orientation of these caps and how it relates to the board layout drawing in the manual. Based on the diagram both caps have one lead on chassis ground and per the schematic this is the positive lead.
I was noticing that my machine doesn't have a turn-on delay and was learning about it in this thread: Harman Kardon 330c massive DC offset and hum at turn on and after recapping the PS, EQ and most of the main amp board, I still get instant sound. I did buy the replacement transistor to put in and have the resistors to check, but I did fail to buy a couple 1000/10 caps for the main amp board so that made for a nice stopping point. I'll do the tuner and the other boards in a day or two while I compile a parts order. No big hurry the amp works with those old, tired caps in it. Another note: the board says these are 470/16 caps but the ones in my unit were 1000/10, maybe another thing to look into.
Background on this unit is that it is a multi-voltage unit. Switchable voltage (internal) 100-120-220-240 and as expected switchable FM de-emphasis to be usable in US or Europe.
Gotta mark caps before they are removed and install new same as old coming out, if the unit was working. Manuals and board labels can be wrong. Someone mentioned they put a sharpie mark on the side of the cap toward the front of the unit. Easy enough to pull a cap so marked orient it properly and know how it was installed in the unit before removal.Thank you to both of you!
Quite often the service manuals are wrong and if your memory is anything like mine, (which isn't as good as it used to be) it's out with the camera for lots of before and after pictures. Clear photos don't lie, especially if it's been a year or two since the work on the board was started.I was taking the caps off the P/S and was going to rely on the orientation per the service manual.
hard to tell from your pic. both are ECB. if the top hole is the emitter (arrow on artwork), you have the base connected.Did I solder them the wrong way perhaps?
Yea I remember having to cross the legs. The phono section had static and it's been fine for years now.Yup, they were wrong, resoldered and now it works.
