Poultrygeist
Lunatic Member
You're the one having problems, not me.
Like I eluded to before, if the risk is too great by all means buy new.
I'll PM you rather than saying anymore here.
I use a Behringer DCX2496 in my main rig, and have no hiss. My speakers are dead quiet with gain applied and no load. Not sure what to make of your comments. My current DCX2496 has been modified by adding PS and analoge outputs by Selectronic of France which did improve the SQ, however both the current and the stock unit were and are dead Quiet through my tri-amped Magnapans.
Interesting,
Jim
I was very surprised at the hiss level. It has to be the crossovers, as it's not there with just the amps on, and it wasn't there when I was single amping Bozak Concert Grands with the one of the same amplifiers through the same system. I have two, and they came from wildly disparate places-it's possible that one's faulty, but it sounds fine otherwise. Magnepans are 81-82db/w (I don't care what the factory says, it takes between 250-450w out of my Yamaha PC-5002M to make my Tympani 1B's jump), and so your background noise is going to be 10db less than my 91db/w Bozak Concert Grands. I need to look into the kdcx upgrades.
Did you buy it used?![]()
Used, but in the original box, with the cord never unwrapped. It was a leftover from an install that never got put in.
I was the first one to turn it on.
No. The X1 is designed specifically for certain NHT subs of the era. It has built-in EQ for those models, including your W2. If you have any other sub, the X2 is recommended. The X1 might "work" for other ones, but it won't be optimal.You do if it is for dedicated Subwoofer use, I use one on my W2 subs
Regards,
Jim
"NOTE: The X1 contains special equalization circuitry specifically designed for Evolution subwoofers and tower bass modules only. It is not recommended with non-Evolution subwoofers." --X1 owners manual
I use a Behringer DCX2496 in my main rig, and have no hiss....
I don't recall any particular issue with hiss from mine either, and it's normally connected to a system using 98dB/W/m speakers. Maybe it depends on the combination of settings?
Why do we gotta go there? Isn't there enough difficult issues to deal with in our society without demeaning pigs also? There are bad hombres out there, and nice nice people in all groups. Just leave us pigs out of this squabble.Buying a $20 "pig-in-a-poke"
I would take a Stage Accompany definitely if you want quality. A real good professional PA trade. Also used in the better studio’s etc. Higher quality as Behringer etc., but also more expensive.
See for details: http://www.stageaccompany.com/support/vintage/electronics/SAX60a.pdf
Tom
