Gibsonian, thou art welcome.
As you can tell, I'm a peace-loving guy.
I wonder if Vince can put this formula in laymen's amounts?
I'm the type to end up in the hospital trying to mix this stuff up.
Yes, the detergent mix would be great. If instead you use an ionic detergent like SDS, it might get a little foamy though.I wonder if this would be a good solution for the ultrasound cleaner tank? Can you give me your opinion on that?
This is for old thrifty finds, etc. once you do the first treatment, you will not need the enzyme step anymore, unless you handle your records with dirty hands. I'll post some micrographs and you'll be appalled at what can bind to the grooves.Wow do records get that dirty?
In science we don't deal with drops as they vary with the tip size and liquid viscosity. But we're washing records here, not cloning genes, so I'll give it a shot. The enzyme mix is easy, just empty 1 capsule into 1 gallon of water and mix until all is dissolved (don't skake to mix as you can denature the enzymes). Reminds me, I need to add a note, do not let this solution dry on the record surface! Also, shelf life of this mix is a few hours so discard when done. For the detergent mix, add 1 small drop of Triton X100 to one gallon distilled water and mix. As I mentioned, this stuff is difficult to work with so be patient,. If you first take the drop and mix it with a teaspoon of water to break it up before adding to the gallon it will be much easier. Note, you can buy 500mls of triton off Amazon for $10, that's enough for about 5000 batches....a lifetime of washes. If you want it buffered (optional but recommended) add 3/4 cup of 10x TBE to this gallon. This solution will last months if kept clean.That would be a good idea, like how many drops or teaspoons to a gallon of distilled water. :yes:
George.
That is a problem then - no buffering is bad as all the enzymes are hydolases AND in particular will change the pH of the solution over time (even just sitting). Also w/o pH buffering most enzymes have stability measured in minutes in a cocktail unless you are dealing with RNAase and other fairly stable enzymes). Basically, you are wasting the enzymes as they are not doing anything.
More than likely the source is Apsergillus Niger. Commercial enzyme concentrates have scavengers and preservatives to keep them stable but still the shelf life is measured in months OT.
Actually, most of the enzymes in the digestive capsules are from plant and animal sources. The largest component is proteases, specifically bromelain (from pineapples) and papain ( from papaya). I know a little about papain, as I was the one who cloned the gene for it in 1986. It can retain activity for years in its dry form.
You been a bad boy, James?[emoji33]
hope this helps
Increasing friction is not a good thing IME, for obvious reasons and some not so obvious such as increasing certain types of surface noise........
Yup, I guess the point with Pardee demonstrating that cleaning mint albums can increase friction (depending on agent) is that it eliminates a variable ie contaminated records. However, I have reproduced Pardee's results on both clean and 'used' records - and friction (inc surface noise) can increase in both cases IME. So I reserve cleaning for cases only where strictly necessary, and using agents which don't increase friction - hence my question of Vince1 as to whether he has tested for changes to friction on his regime ?And so is playing a dirty album.
The article stated testing mint albums.
George.
Your records will likely be fine after glue treatment. They only become more brittle after plasticizer removal. The half life of a PVC record is about 80 years. Even if you cut that in half, is it a concern to you? For some yes, others no. It's how clean they play that is important. There's a guy in Europe that has a record "mask" that you peel, just like the glue, but he says it is safe. He won't tell me what he is using, but I will find out.
