Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
Ok, I'm new here, less than 1 year. He is talking about watching threads. I just looked and I have 75 alerts for watched threads. Most of those threads I have not posted in, so it must be working fine for me
No jest intended. I chose to not get e-mails about new posts. Maybe working correctly has something to do with that
I chose to not get e-mails about new posts. Maybe that has something to do with it
OK. I get it. No pun.
Your snippet of quote above explains it all. Unlike your choice, I do choose to get email notifications about threads that I have contributed to. AK has never failed to alert me about new posts until AK started with this new forum format. It annoys the #@*& out of me but until someone fixes the problem, I have to repost to reactivate the new notifications.
Quite frustrating, but in the big scheme of things nothing serious.
Are you sure about that? My phone is so old I'm surprised when something does work, and this new format works peachy for me. I know the emails include to content added to the thread, but if you don't log in you'll be cut off from the notifications until you do.
Apologies if you already knew that....
Incorrect. I've chosen to be notified by email of new posts to threads I have contributed to. It doesn't matter whether I'm logged in or not. I get a notification about a new post to a thread I've contributed to irrespective of whether I'm logged-in or not.
I've been posting on AK since September 2003. Never had a problem with the email thread notifications until the move to the new format. I have posted about this in the appropriate forum.
Sorry...I'm not saying you need to be logged in to receive the email notification, I'm saying if you don't log in upon receiving it, you won't receive any more. It was the same with the old format.
I have the same problem. It happens on all threads if I don't post for a few days.
That is correct, but as you acknowledge, that is not what you said before.
Thankfully it is not universal, for me. The problem is that it is random. I'll never know which of the many thousands of threads I've been subscribed to over the years have been affected by this glitch.
Seeing people use Scrubbing Bubbles, and then using tap water, and cloths, make me cringe. Trying Scrubbing Bubbles is something I might do. But, I have seen several videos online use tap water. Sure, introduce minerals and deposits into vinyl grooves. Not good. And then, use cloths, that can leave dust and fibers? No. I did read somewhere that folks were leaving the Scrubbing Bubbles on for 5 minutes, before rinsing, which does kind of make sense. But, I think I would try this one over wood glue.
For what its worth. An interesting short paper on the chemical compatibility of phthalate plasticized PVC. Just to note - just because a chemical shows to have acceptable PVC resistance characteristics in the table doesn't mean that it is good for use on albums. A small amount of PVC swelling may be acceptable in gross applications (e.g. process piping, seals, etc.), but there is nothing gross about the finely detailed modulations and spacing in record grooves.
http://www.mcnichols.com/resources/.../chemical-resistant-guide-for-pvc-matting.pdf
That's an interesting chart, a great resource to add here. Thank you for linking to it.
Seems to reinforce disuse of the usual suspects - strong acids and oil/petroleum based products. Basically for starters, stay away from anything higher than 1 on the chart.
If you need me, I'll be over here rinsing my albums in a nice Cabernet Sauvignon. LOL
Agreed. Short term, ambient temperature exposure to 2 (and perhaps even higher) ranked compounds might be safe, but why risk it when so many excellent cleaners fall into the 1 category. Even with the safest chemicals, ambient temperature, short duration contact and good fresh water rinsing is probably the best way to go.
I would discourage use of the '88, '98 and '03 vintages.
I'm glad this thread hasn't completely died since Dr. Vince left. I think pretty much all the info we need is in this thread somewhere so even though I'm disappointed with the events leading to Vince's departure I'm thankful for the wealth of information that is here.
Like many others I purchased a Squeaky Clean RCM, and am making a cleaning solution based on the information contained here. I'll throw it out here to see if my math is correct and I've not made any mistakes. Some of the other "recipes" listed use a mix of oz.'s, ml's, teaspoons, drops to the point that I get lost in conversions. Mine is listed in ml's exclusively. My batch size is 470 ml because the containers I plan on using are 16 oz. so 470 ml should do the trick. My 10% solution is equal parts distilled H2O and Isopropyl alcohol to hopefully allow for longer storage times. Here's what I have:
10% Triton solution (50 ml batch):
22.5 ml IPA
22.5 ml distilled water
5 ml Triton X-100
Cleaning solution (470 ml):
40 ml IPA
410 ml distilled water
20 ml 10% Triton solution (9 ml IPA, 9 ml DH2O, 2 ml Triton X-100)
Percentages (by volume):
10.4% Isopropyl Alcohol
.42% Triton X-100
What are people doing about cleaning the storage containers and measuring syringes and beakers before using. I'm thinking cleaning with detergent followed by a IPA rinse. Any opinions?
Thanks,
Brent
I should add that the percentages I chose were based on Vince's suggestions of between 5% & 10% IPA, and .5% Triton for an initial deep clean. All the records I will be cleaning are my original collection that haven't seen a turntable in probably three decades or thrift shop & garage sale purchases.
BrentR79, The math looks good. I cleaned my containers like you are thinking. I am using .5 Triton and 6% IPA ( I also use a quat and EDTA ). Seems to be working good. The liquid in my water trap sure is dirty looking.
Status
