There are 427 reasons why Vince left this thread, and AK.
Yeah, I still don't get it. Then again I didn't read into it too deeply. Just assumed it was an insider thing...Now I understand. Right when I was really re-reading this whole thread again.
Thank you.
No worries. All my posts in this thread are deleted and people can now ask the great painter 427 all about record cleaning. I've moved to another forum. Good luck to all!
Moderator Edit: I restored the content. The author's departure was of his own choosing. He did not want his name attached to AK, so it has been removed.
Luvvinvinyl
Captain, the buffer is optional. It's purpose is to keep a neutral environment and to help stop the enzymatic reaction during the wash. The EDTA in the buffer binds Calcium, Iron, and Magnesium ions that are required for activity and often the main mineral components of tap water. I have used the protocol without buffer and it works just fine. If you want to use a buffer, HEPES/EDTA, Tris-acetate-EDTA (TAE) and MOPS-EDTA are all good substitutes, but stay away from any phosphate based buffers. If you were to buy one component, I would skip the buffer, buy some EDTA and include it with the Triton wash solution at a concentration anywhere from 1 to 10 mM (1 gm EDTA per Liter of wash solution is about 3.4 mM, which is a good starting point) . This will help with mineral deposit removal and also disrupt ionic interactions among bound contaminants. Though very useful, I did not include it in the Triton mixes described above as people wanted the simplest mix with the fewest ingredients. Including it makes your wash solution that much better. A "Tweak" if you will, much like adding a Quat. Hence, my "Ultimate Wash Solution" is:
Triton (0.5%), EDTA (5 mM), and Behentriammonium Chloride (0.05%) and, occasionally, 5% IPA.
I think I did supply you with links to both did I not? I found them by searching Amazon using the words Triton X-100 and reagent grade water.Please don't do that, " A simple search is all it takes!" It's not that simple, thats the reason I asked the way I asked. I am not a chemist.
Thank you anyway.
George.
Certainly not difficult, but if you want an apology, you got it.
Sorry I hurt your feelings.
I don't think he was asking for a smart ass apology, either.
Holy crap! All I did was post the links from Amazon and then pointed out that it didn't take hours of searching to come up with the required materials. A "simple" search was sufficient. All the info has also been posted multiple times within this thread as well. A sincere apology was offered as the respondent to my post seemed to have issues with my statement by saying "please don't do that.....". Obviously, I didn't physically hurt the poster nor steer him or her wrong so I must have hurt someone's feelings. That is what I apologized for. Feelings must have been hurt otherwise there would have been no need for the comment "please don't...". I understand why some have withdrawn from this thread as well as this forum. Can't the one that wanted the information just say thanks? Or even just accept the information?
For what it is worth, I thought your request was fine. There is a lot of information in this thread, and more than once the information changed or was tweaked (example: first Vince said 5% ISO was recommended, then he later said up to 15% was probably OK.) Also people were posting a lot of different sources for the Triton X-100 and substitutes. I'm sure reagent grade distilled water is the best, but it is quite pricey, and I'm pretty sure that good old grocery store Distilled Water was deemed good enough.This has really got way out of hand. I don't mean anything to any of you guys that have posted.
I'm serious, have a good evening, everything is fine. I try look at a conversation as if we were sitting down and having a cup of coffee.
Apology accepted.
George.
99% Isopropyl Alcohol was recommended and can sometimes be found locally at pharmacies. This was the Triton I ordered from e-bay, and was the least expensive I could find it:
http://www.ebay.com/itm/191584738397?_trksid=p2057872.m2749.l2649&var=490661097685&ssPageName=STRK:MEBIDX:IT
My "recipe" can be found in post 762. It's pretty similar to others I've seen posted. I haven't used it yet but plan to change that soon. Even though the thread is pretty long, can get confusing, and occasionally off topic or redundant, it really is an interesting read (especially Vince's contributions (guest110)) I would recommend checking the whole thing out at least once through.
Brent
