Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
Some of my records were treated with Last,back in the 1980's. Will the Triton/Iso/water mix be adequate for cleaning those records?
I have a gram scale I could use for getting the mixture accurate, but I'm still confused between the recommendations: should Triton be .5% or .05% of the total mixture? My eyes are going crossed reading so many posts with varying ideas on this subject.
I haven't seen anyone suggest heating water in order to get Triton to mix quicker. Does that not help?
I'm using a modified version of Rushton's formula at double strength because I don't have an ultrasound.
~.26% Triton, ~.2% Hepastat. 2.5mM EDTA.
Drops are a pretty inaccurate way to measure, especially with a fluid as viscous as Triton.
Most pharmacies give oral syringes away for free and can measure as low as .10 of a ML. I have small one that goes to 4ML by tenths and a larger that goes to 10ML by quarters. Both were free.
I use 1:1000 tergitol in US and 1:400 for hand wash.
1:400 is about .25% so that sounds about right.
How do droppers compensate for viscosity changes?
Just got the X100. I mixed 2.5 ml of X100 with 100 ml of Iso. Shook it up a number of times and it looked very clear and no bubbles. Then I added 400 ml of distilled H20, shook it up (in a 32 oz bottle, so 1/2 full of liquid now) and all of the air space got full of bubbles like it was detergent. After sitting still, the bubbles have reduced to just a tiny bit on top of the mixture.
My question is: should I be shaking this each time I use it, or not?
I give mine a little shake before I use it.
Your mix is 20% iso which is quite high. I'd probably have started with 50ml of iso if I was going to use any at all.
So here are my issues after cleaning a few records:
1. The ~30 year old Discwasher brush (it looks like microfiber? with a wooden handle that can store a small bottle of D fluid) is bleeding black when I blot it or set it dripping wet on the counter. It is coming either from the backing or the fabric.
2. The vac wand I made is working great and all the water comes off (visibly) by the second pass. However, after cleaning and rinsing (ie, vacuuming two separate times) 8 records, the wet/dry vac is totally dry inside (a Stinger).
3. Sometimes the labels are getting wet. The red Columbia label on Mr. Tambourine Man got wet around the edges and when I blotted it, lots of red came off. Not sure why some folks don't worry about getting the labels wet, but I need something that works better than slightly clamping down on a metal disc with a foam (it's an exterior round junction box cover for electrical) pad glued to it.
4. Even after washing some of that easy-grip shelf liner, it still leaves a very noticeable and hard-to-remove dull pattern of itself onto the record. I had to remove it and place the records directly onto the smooth plastic surface of the lazy susan.
Recap: I need a better applicator (I feel the foam brush for rinsing is far to wimpy to do a good job washing) for applying the cleaning solution, I need to protect the labels better, and I need a cheap (<$10) pad for the lazy susan.
I wouldn't use that no slip liner for anything vinyl or plastic based. I lined a coffee table shelf with it and it reacted with a TV remote and Playstation 3 controller that were being stored there in less than a month. It was fused to the PS3 controller and left permanent marks where I had to peel it off.
I warned about this phenomenon here at AK over 10 years ago. Unless one has an item they want permanently stuck to shelf liner, it is best avoided.
Same experience I had with the electrical cover and foam protector.
The dent pullers did a good job, but were cumbersome, and more a pita than anything else.
This solved that problem for me.
Help everyone!
I'm trying to go by weight rather than volume (since I have a $10 digital scale, and no cylinders or pipets).
5% IPA 99% (50mL=39.3g, density 0.786 g/mL)
0.5% Triton X-100 (5mL=5.3g, density 1.061 g/mL)
0.05% quat (.5mL=.45g, density 0.9g/mL, but only 80% pure so 0.56g quat, the rest 0.12g is alcohol I think)
EDTA (3.4mM=1g=1.1mL, density 0.9g/mL)
94% deionized water (943.4mL=943.4g, density 1g/mL)
Does the math work for 1-L of cleaning solution? Am I in the ballpark?
... since I have ... no cylinders or pipets...
This raises something I've been curious about... what do you all typically use to measure out these chemicals/solutions? There are references throughout about using pipettes ... and some folks mentioned throwing the pipette away after a single use.
Are there other convenient yet accurate ways (without contaminating)?
What about reuse? (Dishwasher or boiling with a good rinse? I assume dishwasher would leave residue...)
Thanks!
(And... YEA, I finally finished reading the whole thread!)
Like doodahman said
For me, it is a lot easier to put a 1-L container (pyrex) on a $10 digital scale (below), clean it with IPA, and just add ingredients.
https://www.amazon.com/AMIR-Back-Li...pID=41QZcIegWFL&preST=_SY300_QL70_&dpSrc=srch
Processing for making 1-L cleaning solution
  1. Pre-rinse 1-L glassware with IPA, boil deionized water
  2. Start with IPA (5% solution, 50ml, 39.3g) — TOTAL 39.3g
  3. add Triton X-100 (0.5% solution, 5ml, 5.3g) — TOTAL 44.6g
  4. add hot deionized water (94% solution, 943.4ml, 943.4g) — TOTAL 988.0g
  5. add Quat (0.05% solution, 0.5ml, 0.45g, 0.56g of 80% pure) — TOTAL 988.56g
  6. add EDTA (3.4mM, 1g) — TOTAL 989.56g
I do this fresh, each time I want to sit down and clean a bunch of records.
(Although I'm still not sure I have the volume->weights quite right. Any help there? Thanks!)
Just stop by a pharmacy, talk to the pharmacist and tell them you're blending a record cleaning solution, and need something that will accurately measure very small dosage. They have disposable non-needle syringes they'll give you for free. Get a couple.
You're welcome.
What is a low-cost product to reduce static and does that leave any residue after a double rinse, and if it doesn't (leave a residue), how does it work at reducing static after being rinsed?
Status
