Record Cleaning: Developing the Best Possible Methods
Status
Not open for further replies.
No need to do such elaborate effort like this.
Just do it simple like what i described then i personally have been satisfied with results.
Btw warm water can make your vinyl warped a bit, becareful not to apply such heat to vinyl.
They will warp...
At what temperature did you experience warping, and why do you feel surfactants are a waste of money and effort?
Moderation Note:
New folks to this thread, please read through this entire thread and see what it is about. This thread is not about general actions to clean vinyl. Rather is is about squeezing the last tiny bit out of the process and results. For general vinyl cleaning methods (dish soap, etc), please search for a more appropriate thread, or start your own. I will enforce this, if necessary.
Please stay on the specific topic of this thread.
Rich P
While I agree that a general cleaning with a non abrasive brush and some sort of cleaning fluid as described can be of benefit, taking the next step as described in this thread with as described fluids and ultrasonic equipment has taken my records to another level. I thought my records were fairly clean but I was amazed at the stuff in the bottom of my US tank after most cleaning sessions.
Being able to clean several records at a time in less than 20 minutes also has benefits to me. Just finished all my current collection(245+) and into MoFi sleeves so I'm good for awhile but I am looking forward to the new & improved fluid formula previously mentioned.
My correct EDTA came in today. I'll be curious to add it to the formula and see if I notice any difference.
I haven't had any trouble mixing the Triton so far. I'm starting out with no alcohol.
I've put together a formulation spreadsheet with the most popular ingredients (triton, hep, edta, alcohol) and thought you guys might like it. I've created stock versions with two formulation strategies.
Note, i'm using the edta molar mass from Making Cosmetics at 416g/mol. I've seen other quotes at 380g or so but the 416g matches that of the CAS number specced on a few different sites. Can any of the chemists comment on this?
1. No alcohol. Just enough extra water added to the concentrate to make measurement easy. 2 tbsp or 30 ml per gallon of water yields approximately .26% Triton, .2% hepastat, and 5mM EDTA. 8 ml to 1L water yields nearly but not exactly the same, but is the closest round ml.
2. 5% Alcohol. For simplicity, take 1L alcohol amd discard 75 ml. Add cleaning chemicals in amounts shown. This makes 1L of concentrate. This is a higher volume mix, so throw out 60 ml from 1 liter of water and replace with alcohol solution. This yields 5% iso, .24% triton, and .21% hepastat. For a gallon do the same but discard and replace 225 ml. The idea with throwing out the extra volume of water/alcohol is to be able to use the existing container for storage and mixing. This isn't necessary for the small volumes added using method 1.
The sheet is also "programmed" so that if you want to replace the water in the concentrate with a small amount of iso and add the iso separately you can do that. I didn't make anything super automatic as far as getting to the desired concentration, I wanted to be able to fiddle with the numbers manually to see what I could come up with using easily measured quantities even if the amounts aren't exactly perfect in the final solution.
The exact ratios on these two mixes is not identical, I fudged them to make the concentrates easy to measure out. Shouldn't be noticeable in practice.
Link to spreadsheets below:
https://www.dropbox.com/sh/4ohxieumi08sbuz/AACOWoVXwIclAOOhO__lTTb1a?dl=0
There's one sheet for each recipe for making up 1 gallon and 1L of solution, so four sheets total. Green are inputs, yellow are calculated outputs. Feel free to tweak the numbers to get the final solution you want!
Cheers
Nathan
Status
