The Spin-Clean is cheap, easy to use, and cleans unexpectedly well if you follow the instructions to the letter.is there any good ( simple) method which doesn't include any machine?
Ok, I do see that. But after further reading, the document seems to be riddled with trade names and I don't say a conflict of interest disclosure by the author. So I think I'll pass.I'm in the UK and the link (in the big red box about 1/2 way down the page) is in "American" (e.g. color (US) vs colour (UK).
Some of the products are not available in the UK but there's a very helpful table of alternatives (Go to Pg 17 on) along with links to suppliers.
Hope that helps.
I'm in your camp, no room first off, and I think I get them really clean. Never any buildup in stylus. I do the Magic Eraser dip every now and then, examine the stylus with a magnifying glass and light, just seldom ever see anything.ok, i believe ultrasonic is the best, but not everyone have time, money and space to invest in such thing...
or everything about records must be complicated ( i know, i know...)![]()
as far as i can tell, fairy is the european equivalent to blue dawn? i tried this already, and it makes things worse...records sounds like walking through mine fields? i heard stories around me from my friends who use the same fairy method, and they have succeed...it looks like i am doing something wrong, either use too much fairy, or didn't dry them good, or something else is wrong...I'm in your camp, no room first off, and I think I get them really clean. Never any buildup in stylus. I do the Magic Eraser dip every now and then, examine the stylus with a magnifying glass and light, just seldom ever see anything.
No doubt ultrasonic is head and shoulders better than any other method.
AK members turned me on to Blue Dawn dishwashing liquid. It uses a surfactant. Put the record at a slight angle downward in the sink and spin it as the water runs over the lower edge, almost all the way to the label. Get a piece of a soft cotton towel and soak it, put a drop or two of Dawn on it, and scrub the record good in the direction of the groves with one hand, while using your other hand to balance the record, same way you remove from sleeve. Spin it like you did earlier to rinse. Do other side. Rinse both sides again with tepid water a few times.
Drying can be tricky, it's easy to induce contaminants. A freshly laundered cotton T-shirt has given me the best results. Wipe gently in the direction of the groves. Air dry for a few minutes before playing.
It's definitely backyard compared to a professional clean, but it has worked well enough for me. It's free to try, the Dollar Store has the little travelling size Blue Dawn and I've had mine for a very long time already.
Is this the video you're referring to?Go to the "lets Clean Records" site on You Tube . There is an episode where he tests a lot of different popular cleaning fluids. Showing the results with different types of cleaning machines. The best ones aren't cheap but there are some mid priced ones that come very close.
I've used pre-mixed Nitty Gritty Pure 2 fluid for about 17 years and have never needed to buy distilled water. KAB makes Pure 2 available as a concentrate, and you do need to mix it with distilled water if you buy it in that form.Its a good thing distilled water is still reasonable as it always a necessity in cleaning records.
Just to clarify, PVC in various applications cannot be compared to PVC in a vinyl record. The formulations vary depending on the application. There can be significant differences in the type and concentration of additives in the formulation. Also a vinyl record consists of a copolymer of PVC and polyvinyl acetate (PVAc) so its physical properties are different from pure PVC.there’s 2 things that that need to be removed.
-Dirt/grime
-Plasticizers that have leached out (new records, and records coming out of storage)
Soap and water will remove both of these.
We did a study for Tesla back in the day, pvc instrument panels, but it’s a similar plastic.
Fairy dish soap is similar to Dawn with some different ingredients but like all dish soaps, it contains a significant amount of anionic surfactants, as high as 30%. For cleaning records, only nonionic surfactants are recommended. Dish soap will remove much of the contaminants on a record surface but the anionic surfactants in the dish soap will bond to the record surface and are difficult to remove. It requires extensive rinsing and physical contact to remove the anionic surfactants. In fact, the most effective way that I found to remove all the anionic surfactants, when cleaning records with Dawn, was with a distilled water ultrasonic bath.as far as i can tell, fairy is the european equivalent to blue dawn? i tried this already, and it makes things worse...records sounds like walking through mine fields? i heard stories around me from my friends who use the same fairy method, and they have succeed...it looks like i am doing something wrong, either use too much fairy, or didn't dry them good, or something else is wrong...
i have some more not so important records to try again, but so far i didn't have much luck...
On the other hand, many just enjoy tying a piece of line to their big toe, fling a night crawler out there and close their eyes.....no problem with that either.....carry on, amigos!Just distilled water no chemicals. There is also a microscope picture to compare before and after.Simplify your life.
Get a HumminGuru ultra sonic cleaner. Just add distilled water. Nothing else.
I always run a new LP through the 'Guru. Used records usually get the long wash (10 minutes).
If by some chance I received a filthy LP I'd go the manual route, then into the 'Guru.
Considering that 3000-6000 psi pressure is exerted on the record grooves from the stylus, it is not even an issue with a nozzle pressure of 175 lbs. My first testing of a pressure washer was with a 3600 psi washer, with tap water and holding the nozzle 4 inches from the record ,in the same place for 5 minutes, didn't damage the record at all. US cleaning is one of the best methods but has some issues when used to clean records. You sound like you aren't interested in cleaning your records better than they are in a US machine, that I understand perfectly. Actually viewing the record with a microscope showed an improved result using the pressure washer as compared to the US cleaner and Vacuuming.. These are before and after pics. Hard to argue it is almost perfect which doesn't happen with the US cleaner. No chemicals and no requirement to rinse either. I air dry in an 8' by 8' room that has a Hepa filter running 24/7.This video gives the impression of shooting water like that to be harsh to the delicate shape of a record’s grooves let alone of the label being saturated and at serious risk of harm.
The cavitation of tiny bubbles, some micro sized when using US methods allows for a much more gentle procedure and treatment of vinyl grooves. Also, the big cumbersome handle of the illustrated method and hose if accidentally mishandled can cause harm to the record being sprayed.
The method I use is economical in cost and worlds apart more effective. Below is linked a basic and low cost method similar to what I use which has been very effective. The use of elaborate methods which eat up time and the wizardry-like use of many different chemicals is not only time consuming but, unnecessary as is rinsing if done correctly..
The method I’ve mentioned earlier is not only quick and easy but, also safe and thorough in the final results achieved.
The use of ‘dry’ methods with out the needed the fluids not only increases static-charges but, results in simply pushing dust and debris around while increasing those static-charges. These ineffective methods do-nothing to remove greasy finger prints or related debris.
For me, after cleaning of over 3500+ disks with the US method and using vinyl for many decades there is no other economical method that I know of. Even if air-borne dust attach itself when removing a disk from its new and clean sleeve can be removed with a ‘Zero-Stat’ or even a hand held rubber blower bulb as necessary.
It’s disheartening and frustrating to read so many ineffective and on the cheap methods from so many reluctant to face the music about tried and proven cleaning methods required for serious listening.
The News and methods of US cleaning have been described and made available to all here for more than a decade so there’s no reason to wastefully pursue other methods in 2025. One can look on Amazon or Temu for low cost US 6 liter vats and related tools.
FM
BELOW: System #1, a vinyl lovers dream playback system.
FM
873
The optical microscope is a great tool to observe gross contamination on records but due to its limited resolution, it cannot detect whether any lower level of contamination is coating the sidewalls of the grooves. This requires more surface sensitive analytical techniques such as Scanning Electron Microscopy (SEM) or Photoelectron Spectroscopy (PES) as examples. The large particles observed with an optical microscope typically are responsible for the ticks and pops when playing a record. The contaminants that coat the sidewalls of the groves typically affect detail and clarity and increased background noise when playing a record.Considering that 3000-6000 psi pressure is exerted on the record grooves from the stylus, it is not even an issue with a nozzle pressure of 175 lbs. My first testing of a pressure washer was with a 3600 psi washer, with tap water and holding the nozzle 4 inches from the record ,in the same place for 5 minutes, didn't damage the record at all. US cleaning is one of the best methods but has some issues when used to clean records. You sound like you aren't interested in cleaning your records better than they are in a US machine, that I understand perfectly. Actually viewing the record with a microscope showed an improved result using the pressure washer as compared to the US cleaner and Vacuuming.. These are before and after pics. Hard to argue it is almost perfect which doesn't happen with the US cleaner. No chemicals and no requirement to rinse either. I air dry in an 8' by 8' room that has a Hepa filter running 24/7.
