After the year of using the vat and rotating spindle which rotated at a set speed, I felt I’d get better cleaning results at a slow speed. It simply made more sense to have more bubbles hitting each groove.
That same year the maker of my set-up offered a small black-box which could vary the rotating speeds.
Well, it improved the cleaning cycle and my end results proved it. Back when I purchased it, it was only $89. extra cost but, worth every cent.
On a motivated day, I can plow through 40+ disks a day. Again that would hinge on each disks condition.
Typically, I use about ten minutes per vat run. I’ll start early as each vat-cycle takes the allotted time plus time to allow to dry by slow-speed fan which is a few minutes only. Then inserting each newly cleaned disk in a new poly/paper sleeve and new plastic outer jacket, I also include a small note indicating date, fluid mixture amounts so I can repeat when necessary. To be honest, there’s not much of a difference by adding or subtracting either alcohol or the Ilford equivalent that I use. Also, I find the smaller sized jacket stays on the outer cover better than the 12.75 inch jackets. Additionally, I have learned that Kodaks Photo-Flo is too greasy and tend to remain on a disk, that’s why I use Ilford’s version of it.
While I’ve personally perfected my technique in vinyl cleaning, the biggest effort and stumbling issue has been vinyl storage. With so many disks and limited storage, many have ended up in vertical position on my listening room floor. I must indicate that having all of these hundreds of disks on the floor and creating a crowded situation it has also altered the actual acoustics of the listening room and as a bi-product and I’ve noticed that I do not appreciate the lessening of bass response and crowded conditions. Apparently, I didn’t think that fully out especially when in a one month period I went all out to clean as many disks as possible averaging 40 individual disks a day which led to the crowded conditions.
FM
P.S. As a plus regarding my cleaning efforts I must say that one of the quietest running in the groove cartridges is the Lyra Delos and it has added to my listening pleasure exponentially. Read the big magazine reviews as they will attest to this fact.
Below is not where I purchased my set-up but, it’s an equivalent if not the same.
P.S. II Back when I started with the US method, there were many opinions as one can usually expect but, I found the simplest methods are the best.
I also went through similar debates when I used the VPI 16.5 machine with people suggesting all kinds of esoteric special fluids, and there too I found it over blown and bordering on neurotic and with mixed results.
FM
