hotwheels22
Hi hotwheels22,
You should take the backs off and take a look at the crossover capacitors, if you haven't already, to verify the capacitor values, as there seem to be a few versions.
If they are, indeed confirmed to be the, the 6 and 64 uf items.... Looks like these will work and you'll need 2 of each. (1 each type per speaker)
2 x 6uf: https://www.madisoundspeakerstore.com/solen-capacitors/solen-6-mfd-fast-cap-400v/
2 x 64uf: https://www.madisoundspeakerstore.com/solen-capacitors/solen-60-mfd-fast-cap-400v/
If you want clarity instead...
6uf: https://www.madisoundspeakerstore.com/px-cap-250vdc/claritycap-6.0-mfd-px-range-polypropylene-caps/
64uf: don't see one that's close to the needed 64uf.. As I understand these need to be +/-10%.
The MDL should also work fine for the 64uf, but if I were in your shoes, I'd order the 2 solens, so that they have matching voltages/types.
can i also please be a bit pedantic here and try to make sure i understand what you are saying?
when you say “clarity” you are talking about a brand or capacitors and not a clearer sound?
“If you want clarity instead...
> here you are saying why don’t have matching Clarity capacitors for my other set?
The MDL should also work fine for the 64uf, but if I were in your shoes, I'd order the 2 solens, so that they have matching voltages/types.”
finally, what is MDL and what is “uf”? please?
THANK YOU
