sae-7125
speaking from a longevity and manufacturing quality point of view, or lack there of.
owner complained of intermittent operation and eventually dropping out. not to mention the missing rca jack negative/ground. single sided for soldering, mostly, even though traces on both sides of the pcb.
judging by the thermal management or more importantly eventual thermal self destruction (no venting) plus the particular brand of capacitors (samwha) it would be surprising if this model didnt have issues. an unvented metal oven tends to cook temperature sensitive components like electrolytic caps (mid/low grade brand cap) with the greatest of ease.
i have not bumped into a schematic for the mira (version 1.0?) although some have said that 2000 and v3 have same output amp layout. has anyone noticed tech docs for this specific model? given the current easy diagnosis such info would be useful if after repairs there is something else causing issues. would be nice to know bias and dc offset numbers as well.
make/model plus samwha. sorry no "full" face shot, my error.
4 picture view of the full layout.
solder joints so loose that...
a 4 pack of jacks can be removed without ANY solder or heating equipment. a light pull and its out...
the 4 pack next to the new vacancy has one capable solder connection remaining and the pair at the other end of the rca jack array is similarly loose. the thin white sheet of slippery plastic between pcb and metal chassis seems problematic since the soldered side of a pcb can be quite sharp.
perhaps the simplicity of turn tables is where rega shines best, cant say i have ever owned anything from this particular brand. i may do a thermal "circuit" assessment, like with the recent luxman L-400, and see how many trouble spots are waiting to go boom.
thoughts and experiences anyone?
