The point to point thing is nice if you do changes to the circuit after the fact. You can control stray capacitance pretty well (usually a board is better) but you had better not make a rat's nest out of it for that to be the case
I would not worry about using solid state to regulate the filament. However, in your schematic:
The B+ is getting a double whammy as AC line Voltage changes. As it does so not only does the high Voltage change but so does the filament supply for the rectifier. So this makes the circuit more prone to AC line Voltage problems as it will result in greater variation of the B+.
If you are making a hifi amp as opposed to a guitar amp,
there's really not a good argument for the tube rectifier unless the B+ will be too high for the intended circuit using solid state. The trick is to make sure the solid state rectifiers are properly silenced, which is really more a matter of silencing the power transformer when the rectifiers are installed. To this end you need to keep the transformer leads as short as possible. To silence the circuit the best means is a resistor and capacitor in series, placed across the input to the rectifiers. Usually a 0,01uf cap is a good place to start. A variable resistance can be placed in series with that cap and the ideal value dialed in.
Tube rectifiers look cool but unless that's the reason for using them or the B+ will be too high otherwise their day has come and gone.
