atmasphere
Very true! But just because they are still in use is not the same as saying they are the best choice for the job as we see below:In properly designed equipment, this is a moot point. Gazillions of tube type equipment have been produced and are still around being restored.
Tube rectifiers are still very much alive, and people use them every day in new builds.
You can fix that 'vet, and if you spend enough time with it, you'll notice those old V8s just are not as reliable (and I'm speaking from the experience of keeping that sort of drive train on the road for 25 years and 680,000 miles- it was mandatory I bring a proper tool box with me to sort it out along they way...) even though they are lot easier to work on than the modern stuff.There are more benefits to point-to-point than that. Ease of repair. I recently had some resistors fry on the input pcb of my Dynaco ST70. The board was totally fried and needed to be replaced along with all the mounted components. Took a fair amount of time and money to fix. If it had been fully point-to-point, it would have been a simple diagnosis and fix for $2 worth of resistors.
Simplicity is king. If I have a tube rectifier go bad, I open up the drawer, grab a replacement and pop it in. Five minutes max. I have only replaced one in the last ten years. I also don't need to be an electronics engineer to do so but understand the slow start benefits of my GZ32/5AR4 rectifier.
I think we would agree that proper design is essential no matter if it is old or new school. Bad designs exist in both, including poorly laid out pcbs that have ac traces running parallel to dc traces, underrated traces, etc. I coexist with both. But I am old enough to have learned, old technology may not be efficient, but in most cases it is more user friendly. Heck, I can fix my '67 gas guzzling, carbureted Vette with nothing more than a screw driver, pair of pliers and a hammer in most cases.
And that rectifier is a good example of what I'm talking about. In the ST70 you'll find its the most likely tube to fail. Dynaco cut a corner there and really should have had dual 5AR4s to handle the current of the amp at full power. You can't really replace that tube with solid state since the output Voltage will be too high (although I've not tried some of those 'rectifier replacement' things you plug into the socket...). Triode Electronics makes a slightly larger power transformer that drops into that position in the ST70; it allows you to run dual rectifiers. With modern filter caps you can thus have a much more reliable amplifier and one that makes a slight bit more power since B+ doesn't sag at full get.
