The seller pulled the table top board out of the console for me. And he found the original template!
Making progress. I bought and installed new rubber mounts. Was easier to remove and install than I expected.
Looks like I need new idlers. The table turns too slowly and appears the 33 1/3 not making good contact. The 78 side works better.
I think my issue is the idlers as the motor seems to spin find and seems quiet to me.
How do you adjust speed?
Think I'll wait on building the plinth until I have it up and running well. Now off to shop for idlers.
Question, the two idler wheels on mine look different, but the new ones I see for sale do not look different from each other. Maybe they were just replaced at different times. Will the same idler work on both the 33 1/2 and 78 side?
Well now that I figured out it is the same idler on each side, just one side turned oppositive side facing up... Feel dumb I didn't notice that before...
Problem now is I can't find any to buy. Seller laherbau doesn't have any currently listed for sale. Anyone know where I can buy them?
The set screws aren't really for "speed adjustment." It regulates the tension/friction between the idler and the inner rim of the platter as I explained in my ROK Tips page many moons ago.
I hope that helps!
Thanks for correcting my supposition.....that fiction/tension could adversely impact the speed if not adjusted correctly?
Told yo that someone with experience would come along and provide answers and/or pointers related to your specific table.
There are many, many pages on the different models of ROK tables, it can be overwhelming to search through them; great that you provided him a link.
VR
Andy
Thanks, so I could adjust it due to worn idlers, but that would skew the speed. I’m searching for new idlers and will adjust the screws only if needed after new idlers installed. I assume they have never been moved thus likely in the proper location. I’ve learned from other projects to take it slow and not force or unnecessarily adjust things when restoring vintage gear. Thanks again for all the advice!
I wonder if anyone has tried urethane rubber for the drive wheels, I wonder if it would reduce drive noise.
As far as the plinth, some clamps, a router to cut out the inner openings, wood glue, and some wood will make you a good plinth.
I don't think there was such a thing as a "factory setting" for the set screw that's analogous to a spark plug gap setting in a car engine.
When I started messing with these turntables, there was hardly any information available on the internet, so I had to experiment and that's how I discovered how it functions. These are fine tuning adjustments to get the most from a mechanical design.
If I were in your shoes, I'd adjust it to work with the old idler wheels. Getting new ones from laherbau doesn't guarantee that the present settings will be optimal. Might as well get a head start with tuning. Anyway, the reason for getting new idler wheels is mostly for quiet performance. - fresh rubber + new bearings = less vibration and noise transmitted
Truth be told, I had to adjust those screws for all these three idler wheels when I did the ROK Tips redux article update. I also did the same for the laherbau which I got at a later date. Thanks to Andy's recommendation, they are good!
Here's mine. Plinth was made from a cutout scrap of 2" slate from a Garrard 301. Enjoy the table. Good stuff.
Jim
