I'm not exactly sure what the pushbuttons on a 2325 look like, but for other Marantz receivers it may look like this, and the inside contacts like this.
You want to spray some Deoxit D5 into wherever you can find a crack in the housing to get some onto the contacts, then work the switch in/out many times to try to clear the oxidation. In particularly bad cases the contacts can be badly tarnished black and are difficult to clean without disassembly. Be careful not to overdo the spray, it can get a little messy and oily inside the switch if you spray too much. There is a way to remove the whole sliding plunger, but you risk losing some of the small springs and contacts in the process... do it at your own risk. There may be tutorials on AK on how to do this.
