angelaudio
R724: 565ohmsKeep R721 out for now.
Test H706 emitter to collector out of circuit, but also when you pull it out to test can you measure the resistance from the H706 solder pads from the emitter to collector to check for a board short.
C712 is out of tolerance, but not a short so it probably needs to be changed, but not the cause of the 60v.
I still can't figure out why the voltage divider network that connects the +60v to -60v does not have the correct voltage at the middle? It should be close to 0v?
Maybe do a quick resistance check in circuit. Compare measured R of R724 (560 Ohm) compared to R725 (560 Ohm) and R722 (27K) to R723 (27K). Or compare with your good deck.
R725: 566ohms
R722: 26.73kOhms
R723: 26.88kOhms
