Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
HI, Can anyone recommend a repair service near Framingham, Massachusetts. The right channel has very little sound on my Pioneer SX-950.
Thanks in advance.
If we presume that the switches and controls have already been cleaned an exercised, does the problem exhibit itself with all sources, any speakers, headphones?
Thanks in advance.
Could be just a dirty switch. With the power off, exercise the Tape monitor 1 switch at least 50 times. All signals go through it, that's how it "overrides" everything else. Then power it on and at lower volume see if it made any difference by more exercising. Then if no change try the speaker switch at low volume several times to see if anything changes. Switch contacts get tarnished over time, especially ones that don't get used enough to scrape themselves clean with use.
