Rescuing the KLH 6 Twins from the Evil Garbage Truck
I've got a variety of units to power them. Haven't made a choice. Here's what I've got.
Realistic STA-795 Receiver
NAD Monitor Series 7000 Receiver (Needs help. One channel is weak)
Technics SU Z990 Amp
HK 3390 Receiver (Don't really like this one. Sounds too flat)
Dynakit ST-70 Power Amp (Totally original and totally needs a complete rebuild)
I really want to power them with the NAD, but I've got to get an oscilloscope to do a trace on the weak channel. I've got it narrowed to the pre-amp section. The Dynakit doesn't have a pre-amp right now - even if I had already rebuilt it. For now I'm testing with the Realistic.
FYI I had a HK 3370 which I gifted to a friend. It had pre-out, main-in that I used an eq on to wake up the preamp section. Ended up being decent with the EQ added.
Progressing nicely. Feels good to get a great set of speakers sounding and looking great again doesn't it?
Glenn
I've used woodworking superglue to re-attach such splintered veneer. Seems to work just fine.
You can get the glue, and the activator spray that cures it, from most woodworking supply stores. I'd get the "thick" variety. Just apply sparingly to the cabinet under the splinter, press it into place, and spray it with activator. Be SURE you have it EXACTLY where you want it, before spraying it. Once it cures (which will be immediately), you can then take a sanding block with 150 grit sandpaper, and gently smooth everything down, as needed. If needed, apply a little wood stain to the area, to blend in the color (the nice thing, is that sanded superglue will also take stain- and it will look amazingly like part of the wood, if you do it with care)...
Regards,
Gordon.
Lots of progress. Got the grills done. I ended up repainting them black. The shadow from the woofer and tweeter was too much contrast through the burlap. It worked better to paint it black. The contrast between the hole and the grill disappeared. I used 1/4" staples and luckily they didn't go out the other side of the grill. Put the badges on that geekyshrink (from ebay) provided. Put a short strap from material I found in the fabric department at Wally world. Here are some more pics.
Worked on the cabinets. With one coat of the WATCO, it looks terrific. I sealed the surrounds with the dedicated compound from Vintage AR (from ebay). Here are some more pics.
Well, I've put them altogether. They look great! I've got to color match the chips that I filled which didn't stain and I have to find a jumper for the B+C connection for one. (Anyone got an extra?) I will pause and think if I need to do any more work on the finish, but it was time to hook em' up and give a listen........
Sounded great for being over 50 years old! Pumped some Sinatra and some Jimi Hendrix through them. They definitely don't have the imaging of some of the newer mid-FI speakers I've heard, but they are really pleasing to listen to. They'll look good in any room.
Here's some notes on things that I learned. This is based on my experience and or research with the early model KLH 6's with the sealed woofers and tweeters. I'll let the experts correct me where I'm wrong or add what they believe is missing. Note that this can apply to the later model KLH 6's, but grill replacement, speaker replacement and cross-over work is easier since you can go through the front instead.
- There's lots of help on AK. Thanks guys!
- Parts are generally available if you are patient - mostly ebay. (Still got to find the B+C jumper, but that is small stuff). I got a pair of KLH tweeters which I think are correct for later model KLH 6's and the B+C terminal jumper for one speaker. I also got the badges (new) from geekyshrink and the surround compound from Vintage AR. I picked up solder, soldering iron, flux and some misc items as well. (All of this from ebay).
- I went direct to Parts Express for the capacitors and resistors. (There is a KLH 6 manual on the site that has a diagram with the specs on the parts. It was simple and cheap to order replacements from PE. They sent along a cool catalog with the delivery.
- When soldering caps, use one of the clamp-on heat sinks between the heat and the cap. Heat is a capacitor killer (especially during soldering).
- On the early model 6's, start by leaving the grills alone if they are still in decent shape. These early models have glued-in grills and you have to cut them off to get to the speakers. If the speakers are still good, then there is nothing in the front that you can service anyway. See below about going through the back to fix the cross-overs instead. If you have to replace the grills, then go ahead and do the surgery necessary, but with the sealed speakers there isn't much more you can do from the front unless the speakers themselves are bad.
- If you do need to replace the grills, pay attention to the grill backing you select. Mine were already gone when I got the speakers. I used 1/4" plywood, but it was not straight. I will be able to live with it, but I think I would be more selective of the material if I do this again.
- When making the grills, I used whatever kitchen plates, bowls or pot lids I could find that were a good fit and used it to draw the circle I needed. I made sure not to cut the circle too close to the edge of the grill to ensure that the grills had enough structural strength that they would last. I had a big circle for the woofers, but I used a 1" strip to draw flat sides on the grill - that way the grills are stronger and I had something to staple the fabric to.
- I chose off-white burlap to cover the grills. Found my burlap at Wally World in their fabric dept, but noticed that Jo Ann Fabrics has an even better selection.
- Found a nice strap material at Wally world in the fabric dept. I used that to put a short handle on the bottom of the grill to make removal in the future easier. It wasn't fancy, but looked good and works good. It could be mistaken for original installation if you didn't know it.
- Use the surround sealant from Vintage AR on ebay. Don't try to make your own unless you really know what you are doing. Don't use Elmer's glue on the surrounds for God's sake. The speaker police will arrest you!
- These early models are generally identifiable by the flush terminal plates on the back with A, B and C terminals. Later models have recessed terminal plates with only two terminals. There was a transition period where there was a mix of sealed speakers and such. I don't have any details, but if you think you have one of the speakers during the transition and you aren't sure what to do, go ahead and ask the community.
- To take off the terminal plates on the early models you need to take off all of the nuts and plastic washers on the A, B and C terminals and the tweeter switch. I put blue tape around the plate on the wood and gently used a putty kniife and small hammer to loosen the small nails holding it down. careful not to bend the plate, chip the wood or otherwise damage the speaker or terminal plate here. Once you have that loose take the plate off. Put all the washers and nuts back on to the terminals or store them in a bag and don't lose them! Assuming no one has worked on this speaker before you will see some old brittle potting material that looks like epoxy. You can chip this out with a chisel, Just try not to damage the switch, wires or terminals. The caps and resisters are going away so those can be sacrificed. When done you can use rubber gloves to gently pull out all of the fiberglass. (If you have big hands, you might have to get help from someone with small hands to help.) You will want to vacuum out the interior. You can blow some compressed air in the cabinet to loosen anything stuck in the corners. Shake out the fiberglass to get the broken potting material out. Set aside the fiberglass while you work on the cross-over. In general you can cut the wires to separate the cross-over from the speaker if necessary - just make sure that you leave enough wire with the speaker that you aren't trying to solder wires back together later inside the cabinet. You want to do your soldering outside the cabinet when it is time to put it back together.
- I didn't do any work at all on the plywood on the back or on the MDF on the front baffle other than to dust it off.
- When reassembling the speaker. Before you permanently close it up, try out the cross-over to make sure that it is working correctly. I tacked in the terminal plate with two of the small nails (halfway holding it in place and hooked them up. I was lucky. They worked on the first try. If the speakers don't work at all, make sure you re-assembled the plastic washers correctly on the terminals. If you don't they will short out and you won't get any sound. (Found in my research).
- When I set the terminal plate during installation, I used some silcon caulking in a small bead around the hole. Just wanted to make sure that I wouldn't hear the plate rattling during Rock and Roll and didn't want air wooshing in and out around it. I wasn't trying to glue it down - the original nails should do a good job of holding it in place.
- Replace all the caps and resistors in the cross-overs. The caps must be replaced on these old speakers - while you are in there just do the resistors too. I got mine from Parts Express. Their prices are reasonable and the delivery was fast. Note that the leads on the resistors I ordered were shorter than I needed which caused me to be a bit creative in the surgery. Not a big deal, but just be aware.
- If you find a set that has tweeters that aren't functioning it is most likely that the cross-overs are gone. (Not my experience, but found this in my research and it make s sense if you know about the lifespans of most kinds of capacitors). There is a chance that when the cross-over went, that it took the tweeter with it. (Failed-to-short and got killed by the low frequencies. If it failed-to-open you may be in luck). You will have to take off the back plate any way. See if you can fix the cross-over through the back and get them working. If they are still dead then trace it down and make certain that it is the tweeter. If the tweeter is bad then the choices get difficult in the early models with sealed tweeters. You may have to ask the AK community for suggestions.... (The previous owner of mine had cut them out and replaced them with aftermarket units. I searched and found reasonable vintage replacements.
- I sanded mine by hand with a HD sandpaper holder. I was careful around the edges where the veneer was thin. I had some areas where I had dings and chips that I could not sand out. I chose to fill them instead of steaming or replacing with new veneer. That has left me with a small challenge of color matching with the stain I chose. Just be aware.
- I used WATCO Danish Oil - Dark Walnut. My gosh that stuff goes on easy. I think that was the easiest part of the whole project. I bought a bag of rags at HD and have enough rags and WATCO left over to do about 100 more speakers.
- My local HD keeps rolls of heavy paper (the kind that paper grocery bags are made of) by the front door for customers to put on their car floor or trunk. I found that paper useful for covering the front baffle and speakers during most of the work. I used the blue masking tape to hold it on.
- I had plans to use velcro to hold on my grills. I found that the adhesive wasn't strong enough and it just pulled away. My grills fit tight enough that I didn't need velcro, so instead of struggling with stapling them in place on the front baffle and grills, I just took them off and went naked. They stay put for me.
Guys. Let me know if I missed anything. Hopefully, with Glenn's thread and this one we can encourage others to restore these beautiful speakers.
Good summary. Just a couple of thoughts. If the surrounds need to be re-sealed
(likely they will), the easiest way to reach the early style woofers is to cut the grill
cloth. It's theoretically possible to reach them from the back, but it would seem
a hassle, and I haven't heard that anyone's done it that way.
Burlap-like material has been shown to attenuate high-end response. Wide-weave
linen is closer to the original material.
Masonite is a usable material for grill backing.
My experience with the B+C Jumper (at least on a pair I had) was that it was needed or the sound was thin. Not sure of the whys and hows of that. I lost one of jumpers so formed one out of a couple of electrical connectors I soldered together and sound came back full. I also learned that even the speaker wire not being attached properly on the B connector can also cause the sound to go thin. Great write up!
The early KLH 6's with the flush mounted terminal plate were setup so that you could bi-amp the woofer and tweeter. They came from the factory jumpered together for a traditional non-bi-amp'd configuration. I've got a piece of wire on the one that is missing that jumper. I'll bide my time and watch for another one to come up on ebay or maybe someone will take pity on me here..... The reason why yours probably sounded thin was that maybe you were hooked up to just the tweeter without the jumper.
Hmm, I'll have to do an A - B comparison to see how bad the burlap impacts the high end. I've got the tweeter switched to "increase" and I've got the treble cranked. It sounds good in that configuration. (Yeah I know... I'm not a purist. I can't enjoy running the tone controls in "defeat". I crank them around till they sound the way I want them to.) Thanks for the tip.
I imagine you'll get the sound you want. I could have said the
attenuation might not be a bother.
Excellent looking restoration.
I thought the same thing but the woofer was producing sound, just not much. It was weird. Come to think of it, I think I removed the plate and the nut on the back side was loose so I just wasn't getting a good full connection. Problem solved.
That jumper can be a piece of wire. Not a big deal.
AR's use a wire jumper.
Congrats on your beautiful restoration! Beautiful veneer on those!
I've got mine dedicated to my Scott LK-72 tube amp, a perfect match! If you don't have a tube amp, I'd suggest getting one when you can.
Cheers!
Cheers!
Hi Glenn,
Funny you should mention a tube amp. I saved a Dynakit st-70 from the garbage truck in the same rescue operation. It needs a total rebuild though. I've got a dual 1226 to fix first and then I'm off to rebuild the Dynakit.
Hi Glenn,
Awesome find! The Dynakit I believe is 35wpc like my Scott. Once you've restored it, you'll have a great vintage tube setup.
Glenn
Finally caught one of the jumpers on flea bay. That was a relief. Just needed to have patience.
I'm going to call this project done at this point and move on to the Dynakit ST-70 refurb. If anyone has an questions on the KLH 6 project I'll be listening and responding.
Cheers,
