petervv
update: it's running!!
hi guys,
- I've disassembled the unit, nothing strange, no loose wires, no sign of burned components
- checked the micro switches (by moving the mechanism by rotating the pulley by hand), they were switching as they should
- rotated the tonearm motor by hand, it moved but not really easy
- unsoldered one of the motor wires from the pcb and ran the motor of a adjustable dc supply, I had to increase the voltage to about 9V before it started moving.
- while running it made more noise than I would have expected so I put a very small drop of thin oil to the shaft at the front side, this lowered the sound level considerable and it also started running at a few volts.
- I reversed the voltage, no problem
- By now I thought why not try the auto mechanism, so I put the platter on and hit the 'start' button. The tonearm motor started moving and just went through the complete cycle without a problem!
Needless to say I'm very happy and will now start restoring the unit according to the instructions from Rich.
regards, Peter
hi guys,
regards, Peter
