Poultrygeist
Lunatic Member
Dadbeh,
How does your Musical Paradise compare to the MW?
Dadbeh,
the MP takes EL34 abd 6L6 both tubes that i love so it has a leg up to start with ....
on symphonic music and real demanding passages the MW runs out of steam i.e. sound gets a little muddy and the imaging suffers a little but for acoustic music I actually prefer the MW. the MW is awesome.
Totally agree PG! Here is a pair of RCA smokies, jamming with Bill Evans. All that I can say is...WoW. Pairs of 6V6 are quite reasonable on the bay, and here on BT.
RCA 6V6s are noted for their musicalilty. Many other brands were manufactured by RCA. Check for the silver printing, RCA codes and the RCA stop sign on the top of the tubes.
Still hard to believe, $99 for this amp off Massdrop, delivered to your front door!
1MOR, still enjoying the 6V6's? Are the tops of yours hot to the touch? Absolutely love the 6V6 sound but a little concerned about the heat and maybe I shouldn't be.
This picture shows the size difference between the big ass 6v6 and the much smaller 6AQ5. They are said to be equivalent tubes except for the pin alignment. But the 6v6 has almost a cult like following while the 6AQ5's are less popular. They both take the MW up several notches in SQ. The 6v6's seem to produce more heat maybe because of increased surface area? You can only touch their tops for a second before pulling away. I don't think the 6AQ5's were quite as hot. Wish I could A/B the two tubes but not possible. I'd love to read more opinions on how the two compare. The sound stage really increases especially with the 6v6 and the MW sounds like a much larger amp.
PG, I like that unobtrusive fan.I've added a small, cheap ( under $10 ) and very quiet HV fan from Walmart to cool the big 6v6 tubes. Does a splendid job and far more effective that the puny pc fans so often recommended on AK. I've used this fan before to cool enclosed tube amps firing down into the vents. My theory is that most audio failures are due to excessive heat.
Ed, I also love Scott Hamilton's Nocturnes and it's one of my favorites. Sounds amazing on the MW.
All my speakers are 93 dbs and above. 3 watts driving 93db speakers can reach extremely loud levels. Headroom is no problem.
In near field you could probably use 89 db speakers comfortably.
Wolverine, there is a 4 ohm tap on the Miniwatt2013. You should be good to go.Thanks! I will take a look at what I have and see if I have something that will work. I know RTA’s are very efficient but are 4ohm.
