Ok, so that was not the +24V supply. But check the other voltages anyway, you never know.
All this sounds perfectly normal, considering the motor is not braking any more. You will have to check the control waveforms when you have that oscilloscope : you need to know why the reverse current is not applied.
I too think it is the problem. Now you will have to find out where the link between the decision to stop and the reversed current is broken.
Let me sleep over it and I will try to send you a list of things to check by then.
I don't remember if my B795 had platter braking or not, I know my Mitz LT-30 does not.
The B795 does not have braking - can't say for sure for the 791 and 291. It starts much faster than 5-7 seconds though, so visto's problem is not just the braking not working :scratch2:I don't remember if my B795 had platter braking or not, I know my Mitz LT-30 does not.
Aha! Yes, please let us know about your findings :thmbsp:it looks like B790 has platter breaking on board.....
Will post job progress and final solution to fix it..
You're very welcome :yes:once again big thanks to jlb2 for help !
Hi visto,
Ok, here is what I think you should check in priority with your oscilloscope.
Basically you have 2 problems, which are the failure to brake and the sluggish acceleration and speed change. Note that both can be related (insufficient braking instead of no braking at all) so you need to check both the braking command and the current in the motor.
First off, be sure to have the B790 service manual handy, what you need is the schematic and layout of the motor control board (page 7-13) and the
control diagrams (page 7-12).
- Check all the supply voltages on the board: -6V, +5V, +6V, +24V.
- Check the brake enable signal. Either the collector of Q7, or the output (pin 7) of IC8 - the latter is probably easier. Revox doesn't say what this signal is supposed to look like, but you should get a positive pulse there when the motor stops. It also shows a signal whe the motor spins, so what you are looking for is a long pulse, only when the motor stops. The voltage of the pulse should be about +5V.
- Check the BRAKE EN 1 (IC4 pin 13) and BRAKE EN 2 (IC7 pin 8) signals. the latter is connected to the move status detector, so check particularly this signal: it should match the waveforms 9 and 10, trace d (bottom trace) when starting (waveform 9) resp. stopping (waveform 10). If incorrect, check points c to a (see schematic around IC 5) to find the origin of the problem.
- Check the waveforms 5, then 6 (see schematic around IC14, IC19 and IC4). Check the voltages as well as the timings.
- Check the current flowing in the motor. It is available through the voltage accross R17. You should see even current peaks indicating all the transistors and coils are working. Again, look what happens when the motor stops. Make a note of the values, timing and waveform (a photo can be useful if you want to show it to us, especially if you have to give the oscilliscope back).
- If nothings looks abnormal, you can try checking all the waveforms of page 7-12. Report everything you find abnormal, the solution might be there.
It's about all I can think of right now. Feel free to post questions and results as you go, I'll try to keep an eye on AK (can't swear I'll be there all the time though, but I'll do my best). If not, someone else might be able to help you.
Happy hunt!
Poor acceleration and braking could be a resistance/ current limiting fault in the power to the motor field power transistors.
A resistance problem in the motor connection will show on the current across R17. A defective reservoir cap will show on the supply voltage (use the oscilloscope set to AC input to check for possible ripple). Check with motor on and off. The transistors themselves are not likely culprits, since they would have to be all fried simultaneously to cause the problem you have.Mainly the plug contacts between the motor control board and the power supply board. Also the condition of the reservoir capacitors in the power board.
Sent from my SCH-I605 using Tapatalk
Irregular current spikes, current value too low... Essentially make a note of everything that may look suspicious and measure the average / min /max current. Also make a photo or a draft of the waveform. If necessary I'll try to look at my own B790 for comparison (probably not today though). Also take a look at R17: if it looks or smells burnt you may have a winner.I'm on my way to get oscilloscope....
What reading should i expect across R17 if the things are bad.....?
Check the voltages on the motor control PCB, just in case there's a bad connection.
Do you mean the waveform at pin 7 is a continuous level wihtout variation? Or is it just the voltmeter reading?Brake enable signal : IC8, PIN7
- at rest mode -2,49V
- at spin up and PLAY mode -3,22V
- enabling STOP - no signal, voltages drops to -2,49V
So no +5V signal (or any other positive signal)
Will check the waveforms now...
BTW also check pin 1 of IC 8 then.
