Revox B790, help needed!
A relatively rare but not-unheard of fault is a diode in the rectifier bridge opening up under load, had this with a BMW motorcycle as a "mystery" problem with a battery going continuously going discharged for no reason when everything always checked OK. You'd see a pronounced dip in the rail voltage at the rectifier reservoir caps in your case during start-up and stopping.
jlb2....
sorry my lack of knowledge is getting essential now...
:pity:
can't get oscilloscope to work as it should be, so no waveforms(unless there will be some online manual for "idiots")..
all other measurements, cleaning, PCB inspection for cold solder etc ,are done - the only thing seems unusual (which i found) is lack of STOP signal at IC8....
:worried:
jlb2....
:pity:
Argh! Actually there are quite a few online basic courses since it is one the basic tools in electronics. I can suggest this one which looks clear enough. I made a copy of the instruction manual of my old Hameg 203, which is very educational too - unfortunately it's in French.
all other measurements, cleaning, PCB inspection forcold solder etc ,are done - the only thing seems unusual (which i found) is lack of STOP signal at IC8....
:worried:
Can you elaborate on this? Which pin and what is the voltage? In the absence of an oscillioscope you can still check whether the voltage changes by measuring the AC voltage. It won't tell you the whole story but at least it will tell you if something is happening.
BTW any luck with R17? Do you read a voltage accross it? You may want to check its value with the multimeter, just in case it was damaged at some point. It should read 10 ohms, and make sure it is directly connected to ground.
I had this problem once, on a Studer A710. The failing rectifier bridge had developed a strange behaviour that made the voltage fluctuate wildy in a more or less random way. After the regulator eveything went well, except when the upstream voltage went low enough to prevent regulation, at which point all sort of odd things happened. It took months to figure out the problem, and 30 seconds to solve it :rolleyes:
In my experience rectifier failures, and regulator chips too, are relatively common on machines of this age. Much more common than electrolytic caps (I saw failed caps just once, maybe two times). The absolute winner is the trimmers though, especially the crappy Ruwidos in the Revox tape recorders, they become brittle and lose contact. I had to replace every single one that was in A/B77's and PR99's. Strangely, the turntables and cassettes don't seem to have this problem - which is good since after replacing the trimmers you have to completely recalibrate the deck.
If you don't find the cause of the failure, I might suggest trying to replace the rectifier bridges and regulators. If you don't know why, they do. And R17 if its value is off. But it's only a shot in the dark.
If you really can't fix your B790, don't lose hope. As a last resort, there is still a Revox service network able to fix it for you. Apparently not in Poland, but in Germany it is still active, and definitely in Belgium: I've met them and they still sell spare parts! A list of the Revox service centres is available there.
jlb2 - thanks for words of encouragement ! :thmbsp:
i will take as much as i can from your link to learn something about oscilloscope.....
combing back to measurements performed with regular voltmeter :
Brake enable signal : IC8, PIN7
- at rest mode -2,49V
- at spin up and PLAY mode -3,22V
- enabling STOP - no signal, voltages drops to -2,49V
So no +5V signal (or any other positive signal)
R17 is 12ohms (i did not desolder it from PCB - so reading could be a bit faulty - pls let me know if it is necessary to remove it from circuit) - looks O.K...?
all voltages coming to motor PCB connector (socket) are O.K (+6V, -6V, +24V)
but... hmmm i can not read any voltage on R17... no matter how i put voltmeter probe it is 0V (or something like +0,02V and dropping down to 0V)
i 'm taking this measurement while platter is spinning...... this is what i don't understand....
here are some pictures of my TT interior...
You're welcome :D
These are just average values though, it does not mean that the voltage is not positive from time to time, to enable current in the motor part of the time. It's got to be, since the motor spins.
It's above the nominal value, but then this value probably includes the resistance of the voltmeter leads.
Now for the interesting bit!
That's strange indeed. Although again, it's only an average value but zero to 2mA looks very low. Check the connection between R17 and ground (should read zero ohms, if you can't have it check the resistance of the leads) - even better, also check. that you do have 10 (or so) ohms between Q6 & Q7 emitters and ground. If there is a problem there, it is not quite impossible that the motor is actually driven by leakage current in Q6 & Q7 :yikes:
You're welcome :D
I had to finish my TT job for today (my wife "is calling". :D)
I'll return to my little project on tuesday evening, of course starting up with All measurements you've mentioned above.
At the end i will replaced R17 with new one (good quality, tight tolerance) and report here on AK...
THX for help !! :thmbsp:
I could also suggest the chips that are in sockets be removed and carefully worked back into the sockets with contact cleaner/preservative if not already done.
You're welcome :D
Sorry for little delay...
- R17 has perfect connection to the ground
- Q6 and Q7 - i have 12 ohms between ground and emitters (same value as R17)
- did double check of R17 - no voltage across this resistor...
frankly speaking i have no idea of what to do in next step....:sigh:
Hi Visto
I used to check this forum more frequently, but have been away for awhile and hope some of this may be useful to you - I can't get as detailed as JLB2, my expertise is Physics, NOT circuit theory!
I've got several B79x TTs, as some people who have read my posts probably know, and I've found that in ALL OF THEM the same re-occurring problems.
1) Replace ALL the Power Supply Rectifiers AND Regulators. ReVox used rectifiers that were barely adequate in current capacity.
2) Replace ALL Electrolytic Caps - I think you've done this.
3) Replace ALL TANTALUM Caps - Your haven't done this, I see them in the Motor PCB and Tonearm PCB pictures.
I can't stress enough about replacing the Tantalums - I had a case with my B790 were the table would sometimes start to spin up and then "chatter" and become unable to sync to speed (although sometimes it would!) - the problem was very erratic. Turns out one of the Tantalums on the Motor PCB was bad - it was about 1uF and polarized and yet the schematic listed it as unpolarized!! I replaced it with a low voltage Polypropylene and that fixed it. I've also had an instance where the tonearm would pick up unexpectedly while playing - always at random spots on the record!! That turned out to be a failing full-wave rectifier on the Power Supply PCB (as mentioned earlier, they can become "flaky").
I've got 3 of their TTs and never had a transistor (regular or power) or IC fail, but caps/rectifiers/regulators have been a problem (did have a power transistor fail on a B77 tape machine, though, that controlled the capstan solenoid). An old EE professor of mine told me to ALWAYS look at components that got a lot of current/voltage surges AND heat.
I'd hit those Tantalums ("pea"/"tear drop" shaped, blue in color) next and replace them with a similar electrolytic and also replace the 3 rectifier and 3 regulators.
Good Luck,
Dale
Hi, sorry for not replying sooner, I hadn't seen your post until Dale's reply brought it back to page 1 :worried:
We already discussed possible failures in the power supply so I guess this part is already done, right? It doesn't seem to explain the symptoms, but just in case... Also, have you checked the +24V and the current in R17 with an oscilloscope, right? A voltmeter will not catch short spikes that do matter here. In any case, replacing the bridges and regulator cannot hurt.
No current in R17 sounds very much like no command signal to Q6 and Q7, but the fact that the motor is spinning says otherwise. Strange indeed. You can only work this out with an oscilloscope.
Rereading the thread, I seem to understand that your problem started when you exchanged the capacitors, so it is a good idea to double-check the new caps to make extra sure of their values and polarities (ambiguous markings? I've seen a few cases), and possily failed new caps (really a rare case but at this point...). Also, double-check all the solder joints with a magnifier and good lighting for cold solder and problems (e.g. cracks) in the tracks next to them. Check the tracks with an ohmmeter if necessary. It is a good idea to take advantage of this moment to replace the tantalum caps as Dale suggested. The next step will be to borrow that oscilloscope again to check the signals on the motor board and find any discrepancy with the nominal signals in the service manual.
As a last resort, I think I have already mentioned that Revox still services these turntables, so you are not on your own.
Gents,
BIG THANKS for your support !!
Finally it is done ! my TT is back in order.
What was wrong.....?
3 IC's were bad (all from motor PCB) IC4, IC7 and IC11), now pls don't ask me how i did it.... :-)
OK, my electronic knowledge is rather small.... so, looking on the schematic i choose suspects, which in my opinion could be responsible for lack of 5V...then get replacements, put them in place... and ....you should see my face while things get back to normal !
Bad thing is that i don't know which of IC's was broken - i replaced all of them in one time - but will not pull them again from socket since this is not easy - so if anybody will experience same story pls put them one by one and see which one is a bad guy..
So i'm lucky owner of 100% operational Revox B790 - this is really good TT - i'm surprised how quiet and neutral sounding it is .....
Cheers !!!
Here is a prime example of why the caps needs to be replaced in these old machines.
I have a short across the big 1000uf cap on the 24V (yes it is the cap, not the rectifier or the voltage regulator).
Here is how it behaves with a non existent 24V:
http://youtu.be/FMrFmXg3bJg
/j
It's good to mention it, because I've had the same problems with rectifiers and regulators too :D At least your problem is not intermittent: I saw a A710 that had a completely erratic behaviour once in a while. It took weeks to trace the problem to a failing rectifier that caused 5V losses once in a while, and µC resets.
I wish replacing all the caps cured all the problems. Unfortunately it is far from being that simple.
Hi all
I restart this post if this is possible ...
I followed carefully all the answers and questions. This really helped me to restore my B790.
Indeed, we do not think about food!
But for the regulators, I can not find to replace those of origins 78HV24 1A and 78MO6 0.5A but in 2A and 1A.
Would someone have found ?
Thks again !
Kind regards of France
Laurent
Hi, no problem using the regulators you mention. But what has happened to them?
