Revox B790, help needed!
Technically nothing, but many users mention that these regulators are undersized. 2A would for example be more favorable, as mentioned boyerd001.
Is this a bad idea?
I can't recall that exact statement, but I kinda recall reading about the rectifier diodes are the ones that are marginal.
What really needs to go is the electrolytic capacitors. I recently repaired a B795 I purchased for $100 about 10 years ago just for the motor and the PSU capacitors were causing all kinds of problems. Even the small 10μF blue electrolytic for -6V was wrecking havoc to the motor control board.
Hi
Thks for your msg.
I changed all capacitors, tantalum and chemical.
I'll do all the welding again, and if I can, clean the relay contacts ... and I'll come back to you.
I have no experience on Revox ...
Thks again
Kind regards
L.
Hi
My Revox is working pretty well now.
But I have a little worry with the arm that stops anytime ???
Thks for your help.
L.
Hi, not sure what you are describing, so I'm guessing based on common problems.
The arm moves with the white string that is threaded to a servo motor to the right side of the tonearm assembly. The string gets dirty and slippery. Can be carefully cleaned with aceton.
The tonearm slides on two stainless steel rods. They also get dirty and get sticky. A lot of cleaning with alcohol on a cotton pad cures that.
The tonearm may have gotten out of alignment. When the sensors detect a large deflection (can be fake but the sensors don't know that) they trigger the cartridge lift signal and the cartridge is lifted and returned to its home position.
I am starting working on my next B790 to fix. I have three of these. One that was working years ago (with a nice Ortofon MC20 cart), another I got dirt cheap because it was dirty as a swamp and a third one that was collected as parts. A turntable without a tonearm (I purchased this years ago to become a platform for an RCM) but before proceeding with this, I found a Linatrack tonearm for about $30 so I could not resist.
All three need thorough cleaning, electrolytics and tantalums replaced as well as the RIFA (all three have intact RIFA caps - anyone cares for one?) and make sure they operate properly. One kinda does, can lock speed (at least on display) but when powered on gives a backwards kick to the platter. The second powers up and when the motor should start rotating, kills itself. The third one is still in pieces so not even powered up or disassembled. Don't know what's inside the plinth.
salut
RIFA est une vraie malédiction !!
J'ai nettoyé le lien avec de l'acétone. La diode IR avec de l'eau distillée et les photocateurs également.
"Le soutien-gorge de Lecture est sur le point d'être désaxé. Lorsque les capteurs détectent une grande déviation (cela peut être un faux mais les capteurs ne le savent pas)"
Est-ce l'alignement du diore IR?
Il y a assez de devenir "chèvre", dit en France.
Beaucoup de choses sur l'IC7 (UA301ATC) qui devrait remplacer (LM301 ou autre (voir photo))?
B795 modifed
https://drive.google.com/file/d/1mtpLJyng--4blTA4fqhuE0b_BdCjuTQ9/view?usp=sharing
open
2 questions about Revox Linatrackers, please:
1. Does anyone know if the platters from the 790 and 791/795/291 are interchangeable? I ask because the one for the 790 is 1.2kg, whereas the others are all identical at over 2kg. I know the motor on the 790 is a heavier duty Papst motor.....nut just wondering if they are interchangeable in order to add extra flywheel effect stability to a 790. They appear to be the same dimensions, even down to the ribs, thickness of top etc, and the mounting points also seem to be identical. Anyone?
2. The gantries for all models are identical afaik, except that the bellows mechanism is changed on later models to a solid affair. Is it straightforward to remove and replace?
Thank you!
The 790 platter is different, since it is the only model with that motor. All later models share the same platter and motor. The platter mass is an integral part of the PLL parameters , so using the wrong one - even if it fits - will degrade flutter figures.
Thank you.
Another question...
My B790 has had all the Frakos changed and has had a pretty complete renovation by a Revox agent, including the Nextel refinish. However, it comes from Austria which I think is a nominally different voltage to the UK where it is now. I read a very interesting article on this... https://www.se.com/uk/en/faqs/FA144717/
My question is: the B790 appears to have taps for both 220v and 240v. Would it be a good idea to switch the two taps from the existing position to 240v? I'm thinking it would cause less stress on the supply?
We are nominally 220v here, with the usual - or sometimes unusually large - variations. I put all my components on 240, and all work fine. The G-36 was the only one that didn't like it .
Sorry, Steerpike, by 'here', I presume you mean in the Transvaal? What would it be best for me to do in the UK.... there seems to be some difference between the'nominal' voltage in the UK as 230v and the usual approximate REAL voltage of 240v. The deck I have received from Austria is probably set to 220v. Should I change itto the 230 or 240v setting? Your advice would be very welcome.
The UK is higher than we have here, by nominal 10 v, so I would recommend setting your unit to 240. It will do it no harm, and at worst it may occasionally act oddly - maybe during times of national grid stress like winter evening . If it works with no oddities , keep it at 240.
