This was a productive day.
First, yesterday I received some brass 1/2 x 13 grub screws and Delrin rod. I mistakenly ordered 3/8 rod which is too thick to fit into the screw without going through or weakening the threads. I cut off about three inches, inserted it into my 1/2” drill and spun it on the bench sander. Quick work there to get it down to the size of the hole I bored into the screw. A drop of thick CA glue to secure it I cut it and sanded it to 1500 grit with the slightest dome.
Next was to fashion an arm lift that would integrate with the arm rather than just look added on. Well…….It works.
I also used inserts and allen bolts to secure the turntable to the plinth. I don’t think the lead shot is necessary and I’m ready to just enjoy it. Did the new grub screw/pad help the noise level? Not sure about that, although my impression is that the sound is a bit more transparent and clear. Bolting it securely to the plinth may have something to do with that. I still have a bit of hum the moment the stylus hits the groove and no grounding arrangement seems to help. I wonder if new motor mounts would improve that. Still, it is a beautiful sounding turntable. Just bought a new DL-103 because this one has a solid year on it. Need to replenish my audio budget………
