The Delrin definitely has more mechanical noise than the stock wheel and I’m not sure why. I ended up using the stock washer on the bottom and two nylon washers on top, securing it with two of the original clips hoping to dampen any tendency for vertical movement. That, I doubted because there is no discernible wobble in this. Still, after this I do hear a bit of mechanical noise even after adjusting the screw for just enough pressure to maintain contact. I oiled the bushing and am going to just run it, hoping it works in. The speed is better and this reading was done with no stylus drag. There is maybe a bit more detail in the low end compared to the stock wheel. Splitting hairs.
View attachment 3164131View attachment 3164132
