Would love to hear what other's feel after installing them.
Thank you Sann for your impressions.
I got my russian paper diaphragms with copper coils also for my Altec 604. They look little different compared to yours as Alex replaced the brass lugs with copper (I asked to do so). I thought that I got wrong parts, as the loading caps could not be used. Here is reply from Alex: "I did this on purpose, my diaphragms should only be used without the loading cap for best sound. You can use an aluminum cover and place a sound absorber in it"
Alex was right. I compared the original aluminum diaphragm with and without loading cap and without the loading cap the sound was far more breathing and natural as I tested 604´s without box (dipole) in my studio with vocal, snare drum, fretless bass and acoustic guitar . I found same results and other good info here
https://greatplainsaudio.com/altec-lansing-compression-driver-rear-loading-caps/ With my earlier tests I found also that the aluminum dustcap (even with loading cap installed) degrades sound also. So no dustcap installed, open back for diaphragm.
Next I compared with same setup russian paper diaphragm copper voicecoil against original "1954 (604C) aluminum diaphragm with edgewound aluminum voicecoil" and "70´s? (604E) aluminum diaphragm with copper voicecoil" (Aluminum voicecoil was about 3db louder, so had to attenuate it, but both copper voicecoils were about the same level, no attenuation needed in my minimalist crossover with only 1.8uf for hf, lf fullrange). The paper diaphragm sounded with all instruments and vocal so natural/breathing/inspiring/lively. With aluminums there was all the time feel that something is wrong, annoying metallic artifact, boring/compressed/dead as compared to paper. And I changed the diaphragms many times, allways clearly the same results
To the end of testing session I removed the "bug filter", fine metal mesh from the throat with sharp knife. Hf souded even better. That would have been clear without testing, as I have had same results on earlier speaker projects - no cover to speaker is best for me allways.
Installed one 604C with russian paper diaphragm (no loading cap, no bug filter) to my controlroom main speakers and compared to original aluminum voicecoil diaphragm 604C (with loading cap and bug filter). With pink noise/spectrum analyzer the hf with paper diaphragm needed no attenuation, as it is about 3db lower sensitivity than aluminium vc, great! The frequency response was quite similar on both, but paper diaphragm started rolling down about 1/3 octave earlier at about 8khz vs. 10khz with aluminum.
Then took some vinyls rolling. Paper/copper vc sounded so more NATURAL and lively, so big on mono with much depth/separation/micro dynamics and I could hear much better the room ambience (important part of recorded sound) and reverbs more clearly. Instruments and vocals jumped clearly more out of the speaker filling the room like "you are there". The aluminum vc. sounded dull/small/metallic as in my earlier instrument and voc tests and even though it has little more highs, it does not make dead man alive.
There is no way back for me from paper diaphragms. Alex has done good job! I was hooked instantly. Just wait to get another speaker rock´n rolling.
