centrons95@h
Hi, last year I started restoring the old SA-8100 which belonged to my mother. I changed all the e-caps (including the ltwo large ones 10 mF 50V, half of the diodes, half of the transistors and the relay. The unit works quite well and the improvement has been noticeable, but there are still some little problems so, after the pilot lamp got dead, I decided to go for a total restoration.
Problems/Questions:
1. With some low volume input (mostly classical music LP) the left channel output is very low, sometimes muted. Same problem (with almost every source, also TUNER ) when I insert the SUBSONIC filter, or even worst the 30Hz filter. I don't know which board could be responsible for this behaviour, maybe the switch unit or the filter amp?
2. I'd like to replace all the transistors, following the list kindly provided by WyattWeeks and corrected by Markthefixer in this 2020 thread:
SA-8100 : low volume right channel problem (RESOLVED)
I couldn't find anywhere KSC2073TU and the KSA940TU which seems to be obsolete (Power Amp and Power Supply board). Are there some alternatives? Btw I am italian, so I am purchasing the parts from https://www.digikey.it/ and not from Mouser.
3. I would like to replace the pilot lamp and the protection lamp with two leds, they have two different codes on part list, but they should be 8V 50 mA each, am I right?
I was thinking about putting in series to the led a diode (1N4004) and a resistor (100 Ohm) , with a cap (100 u) in parallel to reduce flickering (see fig). Is this to complicated? I know there are some ready-made alternatives on ebay, but I'd prefer to do it myself (a bit of fun and a couple bucks saved).
Feel free to answer just one question (or none of course), I really appreciate this forum and the fact that there are still people who help each other out of passion. Thanks in advance!
Problems/Questions:
