MAG_1944
Member
Hi Everyone
I've recently begun to use a pair of headphones with my amp for late night listening, I've noticed a low level hum which doesn't seem to change with volume.
Checks I've done so far, checking between all 4 inputs, no change.
Toggling loudness, muting, tone, high and low filters, no change
Toggling tape monitors, no change
I also took the pre amp jumpers out, no change.
I then hooked my speakers up and got very close to them and was able to notice the hum was also coming via the speakers but at such a low level I've never noticed it before in the 2 years I've had the amp. It was at this point I noticed there was a hum coming from the actual amp itself, only audible about 6" away with the case on. Its the metal cover version of the amp rather than the wooden case version
I've found 2 or 3 old threads about hum on these amps and have read though them and begun some trouble shooting to see if I can identify any issues. I've got a standard multimeter with diode test functionality but no scope or capacitor measurement ability.
Amp is a multi voltage version currently set at 240V, I'm in the UK on "240V 50Hz" but actual outlet voltage is around 247-250V depending on time of day.
I've got both the service manual and schematic and did the DC balance and Idle Current adjustments before doing anything else just encase something was off there, all adjusted to spec but no change to the hum.
Next I made a table to go though and check all the voltages on numbered pins, diode, transistors and FETs. I've listed out the spec voltages from the schematic but please correct me if I've got anything incorrect. Full break down below
Main findings were pin 14 is giving -49.8V vs -48
Pin 15 giving -33.3 vs -32
DC voltages coming out of D9-12 were off +67.3 vs +70, and -67.4 vs -70
This is where my fault finding knowledge dries up and some input for the community would be greatly appreciated.
What other testing/checking should I be doing to establish what the root cause of Hum is, are the low voltages just a symptom of another issue I've not yet found.
One of the old threads mentioned checking the AC portion of the DC regulated voltages, is this something I should check and how would I go about doing it.
Any help would be greatly appreicated
Thanks
Mark
Pin measurements
FETS/Transistors
Diodes
Thanks Mark
Thanks
Mark
Pin measurements
FETS/Transistors
Diodes
Thanks Mark
Use a second Y for three bulbs.
