QSilver
Went to switch it on today and it took longer than usual to come out of protection. Then I heard a slight crackling noise from inside the amp. Turned it off, and smoke came out from the front right corner of the amp. Damn.
So I took it to the bench. R80 had burned up. I changed it and replaced Q16 and Q18 with KSC1690 and KSA1220 - I've seen MTF recommend them on another threat for the 8800.
I then powered back up and the DBT stayed bright Powered off and removed the output transistors just in case they were blown but if they weren't, to protect them.
Powered back on, and the bulb goes dim, and the amp comes out of protection. So I started probing with my scope and found that there is a high pitched waveform near 20kHz on almost all the transistors on the right channel. The left working channel is quiet as ever when comparing. I can trace the waveform back through from the driver stage down to the base of Q14. Here, it looks like a sawtooth. Afterwards it looks similar to what I have attached.
The pre/power amp jumpers are removed.
I've not really dealt with oscillation before and especially with an NSA...
As a precaution I've dropped the idle current down to minimum on both channels. Maybe I'm getting this oscillation because I've removed the output transistors? I'm not sure if the oscillation can travel back through the amplifier or it it really is starting at the first stage...
