SA-9500 Recap
You should be able to "manufacture" posts from ring terminals and 12-14 gauge Romex. Obtain the proper size ring terminals for the size of the screws of the caps. Crimp, then solder, a short (~ 3/4") piece of the stripped Romex to the terminal, and then solder your wires to the new posts. If you feel the need for the dual posts, you may need to go to 16 gauge solid copper, but maybe not with some careful pre-bending of the Romex and crimp end of the ring terminal.
solder or crimp ring terminals that fit the caps, onto the ends of the wires that formerly connected the capacitors. You can pair up wires into the terminals. Use a split ring lock washer to keep the screw tight.
http://www.audiokarma.org/forums/showthread.php?t=194811
attachment.php
Is the Dec 2011 recap BOM list in this thread still accurate??? Has anyone used this BOM and updated it to current DigiKey or Mouser part numbers?
The list in post 5 is complete at Mouser except two ECQ caps, the 0.1µF/50V and the 0.22µF/50V which are NLA and the KSA992 transistor which is backordered right now but there are 19,000 expected around the 18th of Jan. Easy to find replacements for those caps and you can have em ship the order complete and get the rest ready to go until the transistors come in.
SA-9500 and SA-9500II are NOT the same parts list.Very different internally.
The sa-9500II cap list has been done by Mattsd and KingBubba, but is not in marty's master list.
http://www.audiokarma.org/forums/index.php?threads/pioneer-recap-lists-sticky-suggestion.457663
I never finished vetting and reconciling (IF there were any differences) the two lists.
The list for the SA-9500II is very out of date and uses some caps that are not the ideal replacements (ie: UKL used where there should be UPW etc.). It also does not have any of the transistor replacements. I'll revise it and add the transistor replacements here soon.
I have an SA-9500ii that I would like to recap (and "re-trans" perhaps) while it still works. It appears the March 2011 BOM is the latest and perhaps the only one available, but is too old to be recommended?
Mike.
Mike.
It's pretty up to date. Only the ecq caps from panasonic are no longer available. Just sub KL caps from Nichicon or other film capacitors(many use Kemet although they cost more than the panasonics ever did). The values are accurate.
You should start a new thread after you have inputted the BOM. You can then ask for help on what's not available (sometimes the same caps or transistor is available in a different form, like tapped vs individual).
Alright then, I spent the weekend doing my first recap, the SA-9500ii in question and so far it appears (or sounds) to be successful. More testing needed, but I'm encouraged by this first project.
I invested in a Hakko FX888d soldering station to replace my ancient Weller and am surprised by how much better the new iron was. Night and day. I also invested in a Hakko FR-300 desoldering station and can't imagine attempting this without it, though I still had to solder-wick the three caps on each of the power amp boards so as to keep the disassembly manageable.
So here is my cap and transistor list, as well as a BOM, which is mostly lifted from "SA-9500 II Cap & Transistor Lists" by the architect, and the Word doc "Pioneer SA9500ii.doc", with a few updates for obsoleted Panasonic caps.
Changes from previously published lists are underlined (really just Panasonic caps, replaced with film caps). Also, I'm not clear on the naming scheme (CEA, CEANL, etc.) for the film caps and so left it as "XXXX". These are, of course, Mouser part numbers for Nichicon, Kemet, Wima, and ON Semi.
Lastly, this newbie discovered that in some cases the price break for 10 units was so good that it was actually cheaper to buy 10 of an item than 4 of that item. He also discovered that some items may not be available in bulk (aka loose), but are so on a tape, which is just fine.
Control Amp (AWG-045)
AWG-045: C15: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C16: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C17: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C18: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C25: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C26: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C27: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C28: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C31: 100uF 16v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWG-045: C32: 100uF 16v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWG-045: C33: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C34: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C41: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C42: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C43: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C44: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C47: 100uF 16v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWG-045: C48: 100uF 16v CEANL: 647-UKL1E101KPDANA 100uF 25v
AWG-045: C49: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C50: 4.7uF 50v CEANL: 647-UKL1H4R7KDDANA 4.7uF 50v
AWG-045: C51: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWG-045: C52: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWG-045: C53: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWG-045: C54: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
Q1: 2SA640 ecb: 512-KSA992FBU ecb
Q2: 2SA640 ecb: 512-KSA992FBU ecb
Q3: 2SA640 ecb: 512-KSA992FBU ecb
Q4: 2SA640 ecb: 512-KSA992FBU ecb
Q5: 2SC1400 ecb: 512-KSC1845FTA ecb
Q6: 2SC1400 ecb: 512-KSC1845FTA ecb
Q7: 2SC1400 ecb: 512-KSC1845FTA ecb
Q8: 2SC1400 ecb: 512-KSC1845FTA ecb
Q9: 2SC1400 ecb: 512-KSC1845FTA ecb
Q10: 2SC1400 ecb: 512-KSC1845FTA ecb
Power Amp (AWH-052), times 2, as there are two power amp boards, one for each channel.
AWH-052: C4: 22uF 50v CEA: 647-UPW1H220MDD 22uF 50v
AWH-052: C5: 470uF 6.3v CEA: 647-UPW1A471MPD 470uF 10v
AWH-052: C15: 1uF 50v XXXX: 80-R82DC4100CK60J 1uF 63v (Kemet film)
Switch Assembly (AWS-109)
AWS-109: C7: .68uF 35v XXXX: 505-MKS2.68/63/10 .68uF 63v (Wima film)
AWS-109: C8: .68uF 35v XXXX: 505-MKS2.68/63/10 .68uF 63v (Wima film)
AWS-109: C9: .22uF 10v XXXX: 505-MKS20.22/63/5 .22uF 63v (Wima film)
AWS-109: C10: .22uF 10v XXXX: 505-MKS20.22/63/5 .22uF 63v (Wima film)
AWS-109: C11: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWS-109: C12: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWS-109: C13: 100uF 16v CEAL: 647-UKL1E101KPDANA 100uF 25v
AWS-109: C14: 2.2uF 50v Unknown: 647-UPW1H2R2MDD 2.2uF 50v
AWS-109: C19: 330uF 80v CEA: 647-UPW2A331MHD 330uF 100v
AWS-109: C20: 330uF 80v CEA: 647-UPW2A331MHD 330uF 100v
AWS-109: C21: 220uF 63v CEA: 647-UPW1J221MPD6 220uF 63v
AWS-109: C22: 220uF 63v CEA: 647-UPW1J221MPD6 220uF 63v
AWS-109: C25: 47uF 16v CEA: 647-UPW1V470MED 47uF 35v
AWS-109: C26: 47uF 16v CEA: 647-UPW1V470MED 47uF 35v
AWS-109: C29: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
AWS-109: C30: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
AWS-109: C34: 3.3uF 50v CEA: 647-UPW1H3R3MDD 3.3uF 50v
AWS-109: C35: 3.3uF 50v CEA: 647-UPW1H3R3MDD 3.3uF 50v
Q1: 2SC869 bce: 512-KSC2383YTA ecb
Q2: 2SC869 bce: 512-KSC2383YTA ecb
Q7: 2SC1384 ecb: 512-KSC2690AYS ecb
Q15: 2SC945 ecb: 512-KSC945CGTA ecb
Equalizer Amp (AWF-024)
AWF-024: C1: 1uF 50v XXXX: 80-R82DC4100CK60J 1uF 63v (Kemet film)
AWF-024: C2: 1uF 50v XXXX: 80-R82DC4100CK60J 1uF 63v (Kemet film)
AWF-024: C9: 470uF 6.3v CEA: 647-UPW1A471MPD 470uF 10v
AWF-024: C10: 470uF 6.3v CEA: 647-UPW1A471MPD 470uF 10v
AWF-024: C17: 3.3uF 50v CEA: 647-UPW1H3R3MDD 3.3uF 50v
AWF-024: C18: 3.3uF 50v CEA: 647-UPW1H3R3MDD 3.3uF 50v
AWF-024: C21: 4.7uF 25v : 647-UEP1V4R7MDD 4.7uF 35v
AWF-024: C22: 4.7uF 25v : 647-UEP1V4R7MDD 4.7uF 35v
AWF-024: C31: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
AWF-024: C32: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
AWF-024: C35: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
Q1: 2SA906 bce: 512-KSA992FBU ecb
Q2: 2SA906 bce: 512-KSA992FBU ecb
Q3: 2SA906 bce: 512-KSA992FBU ecb
Q4: 2SA906 bce: 512-KSA992FBU ecb
Q9: 2SA750 ecb: 512-KSA992FBU ecb
Q10: 2SA750 ecb: 512-KSA992FBU ecb
BOM
CAPS
647-UKL1H4R7KDDANA | 16
647-UKL1E101KPDANA | 4
647-UPW1V101MPD | 5
647-UPW1H220MDD | 2
647-UPW1A471MPD | 4
80-R82DC4100CK60J | 4
505-MKS2.68/63/10 | 2
505-MKS20.22/63/5 | 2
647-UPW1A331MPD | 2
647-UPW1H2R2MDD | 1
647-UHE2A331MHD | 2
647-UPW1J221MPD6 | 2
647-UPW1V470MED | 7
647-UPW1H3R3MDD | 4
647-UEP1V4R7MDD | 2
TRANSISTORS
512-KSC2383YTA | 2
512-KSC2690AYS | 1
512-KSC945CGTA | 1
512-KSA992FBU | 10
512-KSC1845FTA | 10
Thanks,
Mike.
Matt,
Thank you for posting this list. It saved me - and others I'm sure, hours of work. It is also handy that it is easily pasted to Excel. I'm nearly finished rebuilding my SA-9500. I'm working on the input / phono board. I'm stoked.
There's an error in the service manual that made it to the posted list.
AWK-039: C9: 47uF 6.3v CEA: 647-UPW1A470MDD6 47uF 10v
The service manual lists 47uF 6V for C8 and C9, but 47uF 25V is required. It's correct in the schematic and the diagram (and in the amp). Are you able to edit posts that old?
Thanks again!
Stoked!
Adam
