When the b716 went into Q3, what were the voltages on the other transistors, did you check to see if they stayed the same, ESPECIALLY Q7.... I at least expected to see a pins 3 & 4 reading (this section could be FIXED for all I know) or something saying they stayed the same. If I had other readings I could judge whether or not we have additional damage induced...
Now Q1 looks shorted, but this piecemeal replacement could be hurting us rather than helping us.
Put the 2sd667 into the q1 position...
Either Q1 cures it, or we regroup, with voltage readings on current transistors Q1, Q3, Q5 & Q7 and reconsider what transistors are appropriate where...
for Q1:
2sc1735 100v .5a .8w npn with bce layout (original)
2sc1627 80v .3a .6w npn with ecb layout (possibly blown, inadequate replacement)
2sd667 120v 1a .8w npn with ecb layout (latest, robust replacement)
and recapping (rehashing) what WILL be in the circuit
Q1 replacement 2sd667 120v 1a .8w npn with ecb layout
Q3 replacement 2sb716 120v .05a .75w pnp with ecb layout
Q5 replacement 2sk34 same as original
Q7 replacement 2sc2631 150v .05a .75a npn with ecb layout
HMMM, that 2sc2631 was a GOOD choice with 150v breakdown!!
the higher voltages on q1 and q3 work to our favor, so Q5 becomes our weak link.
and rehashing our available parts... (so I don't have to search back 5 pages for it)
markthefixer said:
2x 2sd667 (Q1,Q2) 120v 1a 0.9w npn with ECB layout
2x 2sd756 (Q7,Q9) 120v 0.05a 0.75w npn with ECB layout
1x 2sb716 (Q3,Q4,Q8,Q10) 120v 0.05a 0.75w PNP with ECB layout (used)
