SolutionRoom
I hate to sound really lazy, but do you have a complete list of the parts that you ordered. I know I could go through this thread (and others) and see what's needed, but some of us are also on limited posting time as well.
It would really be a great help.
Lee.
Yes. But as always... take this parts list with caution and ALWAYS, ALWAYS look at your very own SA-9800 to check the validity of this list to what you actually have in your unit, because they can AND DO often vary. And, THIS particular list is mine and for my specific SA-9800 and my situation. And one final word of caution... this list may have been modified a tad for the order placed, to be used as a guide only. YMMV... Good luck.
Capacitors
Power Supply
awr-194 c2 220uf 80v ceb axial 220 100 647-TVX2A221MCD
awr-194 c3 220uf 80v ceb axial 220 100 647-TVX2A221MCD
awr-194 c4 47uf 10v cea 47 10 647-UPW1A470MDD6
awr-194 c7 47uf 63v cea 47 100 647-UPW2A470MPD1TD
awr-194 c8 47uf 63v cea 47 100 647-UPW2A470MPD1TD
awr-194 c9 47uf 63v cea 47 100 647-UPW2A470MPD1TD
awr-194 c10 47uf 63v cea 47 100 647-UPW2A470MPD1TD
awr-194 c13 2.2uf 50v cea 2.2 50 647-UPW1H2R2MDD
awr-194 c14 2.2uf 50v cea 2.2 50 647-UPW1H2R2MDD
awr-194 c15 100uf 35v cea 100 35 647-UPW1V101MPD1TD
awr-194 c16 100uf 35v cea 100 35 647-UPW1V101MPD1TD
awr-194 c17 10uf 80v cea 10 100 647-UPW2A100MED
Amp Left
gwh-129 c1 2.2uf 50v ceanl 2.2 50 647-UKL1H2R2MDDANA
gwh-129 c11 47uf 63v cea 47 100 647-UPW2A470MPD1TD
gwh-129 c13 47uf 63v cea 47 100 647-UPW2A470MPD1TD
Amp Right
gwh-130 c2 2.2uf 50v ceanl 2.2 50 647-UKL1H2R2MDDANA
gwh-130 c12 47uf 63v cea 47 100 647-UPW2A470MPD1TD
gwh-130 c14 47uf 63v cea 47 100 647-UPW2A470MPD1TD
EQ
gwf-116 c3 100uf 6v ceanl 100 10 647-UKL1A101KED1TD
gwf-116 c4 100uf 6v ceanl 100 10 647-UKL1A101KED1TD
gwf-116 c5 100uf 6v ceanl 100 10 647-UKL1A101KED1TD
gwf-116 c6 100uf 6v ceanl 100 10 647-UKL1A101KED1TD
gwf-116 c7 100uf 6v ceanl 100 10 647-UKL1A101KED1TD
gwf-116 c8 100uf 6v ceanl 100 10 647-UKL1A101KED1TD
gwf-116 c9 100uf 35v cea 100 35 647-UPW1V101MPD1TD
gwf-116 c10 100uf 35v cea 100 35 647-UPW1V101MPD1TD
gwf-116 c11 100uf 35v cea 100 35 647-UPW1V101MPD1TD
gwf-116 c12 100uf 35v cea 100 35 647-UPW1V101MPD1TD
gwf-116 c17 100uf 16v cea 100 16 647-UPW1C101MED
gwf-116 c18 100uf 16v cea 100 16 647-UPW1C101MED
gwf-116 c19 100uf 16v cea 100 16 647-UPW1C101MED
gwf-116 c20 100uf 16v cea 100 16 647-UPW1C101MED
gwf-116 c23 4.7uf 25v ach-318 np 4.7 25 647-UES1E4R7MDM
gwf-116 c24 4.7uf 25v ach-318 np 4.7 25 647-UES1E4R7MDM
gwf-116 c35 220uf 10v cea 220 10 647-UPW1A221MED
gwf-116 c36 220uf 10v cea 220 10 647-UPW1A221MED
gwf-116 c41 4.7uf 25v ach-318 np 4.7 25 647-UES1E4R7MDM
gwf-116 c42 4.7uf 25v ach-318 np 4.7 25 647-UES1E4R7MDM
gwf-116 c45 47uf 50v cea 47 50 647-UPW1H470MED
gwf-116 c46 47uf 50v cea 47 50 647-UPW1H470MED
Protection
awm-163 c1 470uf 6v cea 470 10 647-UPW1A471MPD
awm-163 c2 220uf 16v cea 220 25 647-UPW1E221MPD
awm-163 c3 4.7uf 50v cea 4.7 50 647-UPW1H4R7MDD
Filter
gws-176 c39 1uf 50v ceanl 1 50 647-UKL1H010MDDANA
gws-176 c40 1uf 50v ceanl 1 50 647-UKL1H010MDDANA
gws-176 c41 2.2uf 50v ceanl 2.2 50 647-UKL1H2R2MDDANA
gws-176 c42 2.2uf 50v ceanl 2.2 50 647-UKL1H2R2MDDANA
TC
gwg-124 c7 4.7uf 25v ach-318 np 4.7 25 647-UES1E4R7MDM
gwg-124 c8 4.7uf 25v ach-318 np 4.7 25 647-UES1E4R7MDM
gwg-124 c19 10uf 16v ceanl 10 16 647-UKL1C100KDDANA
gwg-124 c20 10uf 16v ceanl 10 16 647-UKL1C100KDDANA
gwg-124 c29 4.7uf 25v ceanl 4.7 25 647-UKL1E4R7KDDANA
gwg-124 c30 4.7uf 25v ceanl 4.7 25 647-UKL1E4R7KDDANA
gwg-124 c31 47uf 35v cea 47 35 647-UPW1V470MED
gwg-124 c32 47uf 35v cea 47 35 647-UPW1V470MED
Indicator
awv-002 c3 1uf 50v cea 1 50 647-UPW1H010MDD1TD
awv-002 c4 1uf 50v cea 1 50 647-UPW1H010MDD1TD
awv-002 c5 2.2uf 50v cea 2.2 50 647-UPW1H2R2MDD
awv-002 c6 2.2uf 50v cea 2.2 50 647-UPW1H2R2MDD
awv-002 c9 47uf 10v cea 47 10 647-UPW1A470MDD6
awv-002 c10 220uf 25v cea 220 25 647-UPW1E221MPD
awv-002 c11 3.3uf 50v cea 3.3 100 647-UPW2A3R3MDD
awv-002 c12 3.3uf 50v cea 3.3 100 647-UPW2A3R3MDD
Trim Pots
Amp Left
gwh-129 vr1 330k multi offset 652-3296P-1-204LF
gwh-129 vr3 100 single idle 70 652-3386H-1-101LF
gwh-129 vr5 47k single idle 56 652-3386H-1-503LF
Amp Right
gwh-130 vr2 330k multi offset 652-3296P-1-204LF
gwh-130 vr4 100 single idle 70 652-3386H-1-101LF
gwh-130 vr6 47k single idle 56 652-3386H-1-503LF
Transistors
Power Supply
awr-194 q1 2sc1735 pwr pass + 100v .5a .8w 512-KSC2690AYS to-126
awr-194 q2 2sc1735 pwr pass - 100v .5a .8w 512-KSC2690AYS to-126
awr-194 q3 2sa733 pwr darl + 50v 0.15a 0.25w 512-KSA1013YBU to-92L
awr-194 q4 2sa904 pwr darl - 90v 0.05a 0.2w 512-KSA1013YBU to-92L
awr-194 q5 2sk34
awr-194 q6 2sk34
awr-194 q7 2sc1914 fb ampl + 90v 0.05a 0.2w 512-KSC1845FTA (ln)to-92
awr-194 q8 2sa904 fb ampl - 90v 0.05a 0.2w 512-KSA992FBU (ln)to-92
awr-194 q9 2sc945 lv err amp + 50v 0.1a 0.25w 512-KSC2383YBU to-92L
awr-194 q10 2sa733 lv err amp - 50v 0.15a 0.25w 512-KSA1013YBU to-92L
awr-194 q11 2sd712 Replace with 512-KSC2073TU
awr-194 q12 2sb682 Replace with 512-KSA940TU
awr-194 d5 xz-060 main zener 512-1n5233b
awr-194 d10 mz-177 512-1N5247B
Protection Board
awm-163 Q1 2SC945A Replace with 512-KSC2383OTA
awm-163 Q2 2SC945A Replace with 512-KSC2383OTA
awm-163 Q3 2SC1885 Replace with 512-KSC2690AYS to-126
Amp Left
gwh-129 Q7 2SA912 TO-92L Replace with 512-KSA1220AYS TO-126
gwh-129 Q9 2SA726S Replace with 512-KSA992FBU
gwh-129 Q11 2SC1885 TO-92L Replace with 512-KSC2690AYS TO-126
Amp Right
gwh-130 Q8 2SA912 TO-92L Replace with 512-KSA1220AYS TO-126
gwh-130 Q10 2SA726S Replace with 512-KSA992FBU
gwh-130 Q12 2SC1885 TO-92L Replace with 512-KSC2690AYS TO-126
