SA8500 only works on DBT
No just c32 reconnected at that time. And then to ohm out the coloured arrows everything was reconnected hence pad to pad measurements included a component occupying the space, given that I had reconnected everything. I am sorry for the confusion.
OK, so with C16, C24 and C26 disconnected does the resistance still rise slowly to 70k between red and dark blue points?
Ok Tone control switch is on, all pots at TDC, C16 (edited due to typo), C24 and C26 removed from the board, measured at +c16 and -C26 resistance is at 70.3 kohm and gets the very quickly like just a second.
That is good, 1 second or so is probably just meter settling time. Leave things uninstalled just the way they are. Next step is to measure those same points, one at a time, but put the black meter lead to chassis ground and measure resistance. It should read way high or even open.
Reads open on both points
Good, no leakage to ground.
Without reconnecting anything, power up and check for buzz at the + side of C32.
Ok will do that when i get back from work, what points do i test with C26 reinstalled?
Am i still testing +C32?
Yes, as the origin of the buzz seem to be right in that area, if we can determine the feedback path for the oscillation we can isolate it..
Ok reinstalled C26 and there is no buzz at +C32.
Are we putting C16 in again and repeating the procedure?
Not yet for C16, but please do put C24 back in and check for buzz at C32. If it has buzz lift one end of R28 and recheck.
