ÌF there is no buzz when i switch speakers on, i reinstall C16 and try again with speakers to on?
If the buzz comes back when i pop C16 back in what are the next steps?
I know i am moving a bit ahead but this morning i done a very quick check, no buzz from speakers. (To be confirmed properly whenever i get home from work as was rushing as usual)
Leave C16 out and R28 lifted,i have pulled one leg of R28 and rechecked and we still have buzz on C32.
So one leg of R28 is lifted, C16 is still not installed.
Yes, blue circled.C22 is a polystyrene cap, circled in blue in picture ?
@merlynski I pulled C22 and tested at C32 its buzzing
C22 should be 390pf, 406pf is close enough, and is inside 5%.C22 tests on my cheapo tester to 406pf
Will pull C24 right now
Buzz gone?C24 has been pulled
Is this about the same resistance you get with the leads shorted to each other (lead resistance)?0.3 ohm is the result i got +C24 to C22
If there is a good connection from green arrows pad to pad the bump is not likely a cracked trace, but it won't hurt to bridge it with solder.It's really hard to see but I scraped the trace a bit, there is a tiny little bump in the trace, can be felt with fingertip, I wonder is it worth bridging this? I don't want to get excited but have we struck gold maybe??? I'll try get a decent picture but it's very difficult
