Please dont laugh but what kind ofcd is a sacd?
Super Audio CD. Requires a special player.
Oh thanksSuper Audio CD. Requires a special player.
I just read of a handful of 70s soul releases on SACD, which include the original quad mixes, released within the past month or two. These are on the Vocalion label and include Earth Wind & Fire, Harold Melvin & The Blue Notes, The O'Jays and The Miracles (I believe all are originally from the Columbia label--I know EW&F and Harold Melvin are). Anyone who can't find new SACDs or DSD downloads (Acoustic Sounds offers them) isn't looking hard enough.there are still new sacd discs being released by quite a number of record companies, check the usual suspects in vendors like acoustic sounds, music direct, and elusive disc. i assure you, the selections exceed your budgetary limitations.
I don't find that to be true at all. For example, I get fatigued quickly listening to SACDs (or discs of any kind) on my Oppo BDP-103 but those same discs are fatigue free in the 205. I can play CDs all day long in my Pioneer PD-T07 without fatigue of any kind.even though there are those that don't like sacd, it is superior to CD, regardless of their foibles. it gives the relaxed, satisfied sound of nearly as much as LP. CD doesn't deliver that, you are done listening after about one disc whereas LP and sacd allow for longer listening periods without the fatigue that results from compact disc.
Similar here. The Pioneer DV45A was excruciatingly bad on everything it played. Grainy, bright, harsh, an edgy "buzzsaw" distortion especially on CDs that once heard, could not be unheard. My Oppo 105 improved everything quite a bit, but it took stepping up way beyond that to a DirectStream to make digital acceptable to me. It's quite different in how it operates (no DAC chips), so comparing it to other DACs is like comparing apples and oranges. It brings CD closer to what hi-res sounds like, and hi-res (PCM and DSD) is fantastic.For example, I get fatigued quickly listening to SACDs (or discs of any kind) on my Oppo BDP-103 but those same discs are fatigue free in the 205.
@stoutblock
I don't think the sound of a CD player is 100% dependant on the DAC. There are some very good CD transports out there, both internal and standalone, that will actually sound better than other transport units. However, at a given level of CDP performance or cost, the internal transports are most likely comparable, which is probably what you were suggesting.
There are also CDP's that pre-read the CD data, removing any imperfections from the information before sending it to the DAC, which apparently makes the overall reproduction sound better. MSB does that, I believe.
And yes, SACDs sound amazing.
Cheers.
Dave
Picked up the Mofi SACD (hybrid) of The Grateful Dead's Workingman's Dead. Fantastic sound. The original CD used a bit of NR (noise reduction), so the high end had no decay. Always bugged me. SACD sound is true to my original WB "greenie" label LP.
BTW, I use a Marantz SACD player.
I've found about 1/3 of my collection used ... Zia here in the valley.
Want to buy a copy of Jeff Beck "Blow By Blow" SACD. I've seen two versions from Acoustic Sounds, one is from Analogue Productions and the other Sony. Any thoughts on which is preferred?
Thank you Stoutblock!I have the Sony (Epic) version and it is exceptional. It is also surround sound if that is important to you. I've never heard the Analogue version but most of their library is quite good.
