I'm still trying to find the problem on this amp.
To review the problem (I’m hoping
@llwhtt will see this): when there is a drive board (either one of the two I rebuilt) installed in CHA, the Variac/DBT 200W bulb starts to light at about 60v and is very bright at 90v. With a board only in CHB, the bulb does not start to glow at all until 90v and does not get very bright at 120v. I have tried both boards in CHA, with and without the relay board installed, same result. I removed the 80V+ red wire from CHA and the problem went away, so I am pretty sure something is getting energized from the +DC feed on CHA but not on CHB. I don’t’ think I am imagining that the bright bulb is a problem. Before I replaced the output transistors that shorted, I was not getting a bright bulb. Something is wrong, but I can’t find it. I have not attempted to continue to power up the amp in this condition. Through all of the testing on this amp the fuse (10A slo blow) has never blown.
@hamrules, I double checked the wiring of the 80v+ DC feed. It comes directly from the capacitor (one wire for each channel) to the collector of Q17/Q18, and then to Pin17/Pin18 of the Molex connector at the driver boards. On the CHA side this pin is the third pin, counting from the front/relay board side of the amp. Also on the CHA side, there is (was) a jumper that connects from the feed to the trace that brings the 80v DC via Pin 45 to the relay board. There is nothing else connected to this trace. Removing the jumper separated this trace from the 80v DC feed. The power down mod now feeds DC to Pin 45 at the relay board, and the trace to nowhere, from the new diode and cap. AC is fed to the anode of the diode directly from the secondary of the transformer, with the connection being made at the bridge rectifier. The cathode is connected to 10uF 160v cap and to pin 45. Just to make sure this is not causing the problem, I removed the feed wire from the bridge, and the problem did not go away. The relays were working fine before the transistor issues, with this mod installed, .
Following the schematic (and what is in the amp) I am trying to find something that is not the same on both channels and so far, I have not found it. I started with the output transistors as that is where the +DC is physically connected to the output board.
I took apart the output module- again. I checked each output transistor, all fine. I pulled and checked the bias transistors, fine. I checked all of the caps and resistors on the output board, fine. I checked with an ohm meter between ground and all of the terminals on the OP transistors, nothing. I checked for continuity between all solder pads etc. that are in close proximity, no incorrect connections.
I’m still assuming the problem is not on the driver board(s), since the problem only occurs on one channel, regardless of which driver board is in that channel, but I checked them again. I checked all of the diodes, many of the resistors and everything seems fine. Nothing looks burned.
I poked around on the display and gain boards, but nothing is connected ground that should not be or differences across channels.
I am not sure what I expect to find. I have not found a dead short or something different from one channel to the other. It seems like there may be a connection, but perhaps at very low current, like through a component (perhaps a transistor) that is conducting when it should not be.
I have, of course been doing most of this trouble shooting with the power off. If it is not detectable with the power off, but causes the issue with the power on, I'm not sure how to find it.
I can’t think of anything else to check.
I could use some fresh ideas.
