SAE mark one
mike2011
Member
found this mark one at goodwill today , it clicks when powered on , but no power light , dont really have a way to test further , would anyone know if the click indicates power? thanks,, mike
Yes, the click indicates something inside is getting power. Whether that power is doing anything it should is left to further testing.
You can use that thing in the tape loop of a chunk of gear to see if it works.
Your tape output into the AUX input on the I and the main output to the tape monitor/input/play on your unit. Then with the unit on and the volume of the I and your unit ALL THE WAY DOWN, you can start to see if a signal goes through it with the two volume controls. Slowly increase the volume of your unit to say half of normal with some source playing, FM, Phono or whatever, then select tape monitor (careful with those volume controls, select with them both at zero again) and then see what you get.
If you don't understand all this, call a friend for help.
I have a similar SAE preamp. The SAE Mark gear is built like a tank and sounds great it is very sought after and collectable. The power light may be burnt out. I don't know what the click sound means. If I was you I would hook it it up to an amp and some speakers and see if it works
Good luck.
"click" is probably a"muting" relay. That gives the pre-amps amplifiers DC offset time to stabilize.Prevents power-on/off "thumps".
Whatever it is, get it up and running. It is a GREAT preamp, the best of the SAE lineup in sound and quality and the feel and built easily goes heads to heads with the greats from McIntosh and other high quality preamps. Did I mention it is a GREAT preamp?
Good to know! Thanks!
up and running
we tested it turns out it has to sit for about 6 seconds for the light to come on it works fine just a little flat ,prolly needs recapping
