Just picked up a Sansui 1000X. Noticed it was very weak at pulling in stations, so went through the alignment procedure. I fed the signal through the 300 ohm FM antenna connections. I set 88 and 108 MHz dial positions using my THD meter for minimum distortion adjusting controls per manual with several iterations. Then went through the procedure for 90 and 106 MHz per manual. This all went well. Signal meter moves as expected when tuned in. Put in a stereo signal and set for max separation per manual. Everything looked good. On a mono signal I was down to about 0.5% THD.
However, when I connect an antenna in a good location in the house, I can get the stronger stations, but no stereo, and signal meter does not move as though the signals are very weak. I've not experience this with aligning my other tuners. After alignment all works as it should. What am I missing on this one?
but that sure makes sense.
