Sansui 3000A terminal screws. Does anyone know where I can buy these for cheap?
But the 3000A has a 4 terminal with middle space layout as seen here:
This might be close:
http://www.allelectronics.com/make-a-store/item/TER-705/5-POSITION-TERMINAL-STRIP-PC-MOUNT/1.html
http://www.allelectronics.com/mas_assets/cache/image/2/0/e/2/8418.Jpg
Or http://www.digikey.com/product-detail/en/38720-3205/WM5731-ND/362448
Typically, these use 6-32 type screws. OP should take a screw that he still has down to Home Depot or Lowes to check and see if they have similar.
If you need the actual screw and not the terminal bit, you can probably get a bag of more than you'll ever use from McMaster-Carr for a couple bucks.
I doubt they are 6-32, but are metric....but I don't know for sure.
Measure the thread pitch carefully, the wrong thread will ruin the female threads.:thumbsdn:
Yes, basically I just need the screws. The yahoo I bought it from had wood screws in it lol. I hope he didn't go too deep with them otherwise the threading would be shot. I'm going to give this tubesandmore.com a try. I see there about 30mins from my house here in AZ.
