troutmaskrep
I purchased a Sansui AU-317 off of ebay a few months ago in non-working condition to force myself to learn how to fix it. I have no background in electronics or electricity, although I did just recently complete the building of a Dynaco ST-70 and learned basic safety as part of that process.
Quick background:
- amp powers on with no relay click (i'm not focused on this aspect at the moment)
- i measured the power amp section voltages and they appear to be roughly as expected
- power section appears to be ok
- the preamp board however is not ok. the voltages are all over the place
- there are other spicy details of things I found that were not right - i will share once we get past the current hurdle
As per the attached screenshot, there seems to be a big problem at the junction of TR04 and TR06, where the expected voltage is 0.5vdc and the actual is 19vdc.
At first I thought the 8 volt drop across R16 was an issue, but ChatGPT assures me this is normal for a 1.5k ohm resistor according to Ohm's Law. I don't know if I can trust it but it did the math and it seemed reasonable.
It may be worth noting I am seeing this same 19vdc voltage in two other unexpected places - the junction of R18 and TR08 and the test point at R10.
I haven't tested any individual components yet - I don't want to get into shotgun repairs either. I may replace 'fusistors', caps etc once the fault has been diagnosed and repaired, or I may just stop there.
I'm hoping someone can interpret the schematic to point to the actual cause of the problem, or suggest a reasonable next diagnostic step.
Thank you for your time
edit: the attached schematic is of the preamp right channel
Quick background:
