Hi,
Well done re the TR604 replacement.
Re the relay not engaging after the turn on delay, this can be due to higher than normal DC offset being present. This can be due to a fault or adjustment having drifted. You can check the DC offset on each channel by measuring the DC voltage between one of the bias test points and ground (chassis). it doesn’t matter which bias test point you measure on each channel. You can attempt to adjust the offset voltage if it is more than a couple of hundred millivolts. If it measures high (positive or negative) it is likely that a component or several components have failed or have gone out of spec. In any case measure the DC offset by measuring the DC voltage on one of the bias test points on each channel and report back.
Cheers
John
Cheers
John
