Sansui au-11000 transformer
quadmatrix82
AK Subscriber
Hello Sansui experts I have a Sansui au-11000 with a shorted transformer can I subsitute with a au-9900 transformer ?
Unfortunately the power transformers for these two models are different, I think the secondary voltages are higher for the AU-11000.
10Vac difference on the low current winding and 12Vac difference on the high current winding, - too big a difference to ignore.
Are you sure that the transformer is shorted? That unit uses what appears to be a torriodial core transformer (Round Case). If you measure the primary, many times they ohms reading is very low, appearing as a shorted winding. Transformers usually short and then open if they fail, and that is pretty rare unless someone replaced the fuse with the wrong value. A good indicator of a "Bad" transformer is a strong burnt smell by the openings.
Have you tried removing all of the secondary fuses, and attempting power on, looking for AC voltage on the secondary?
Definitely do what Tom B suggests. If it really is shorted, I'm guessing the short would be the primary winding as it usually has the smaller wire. I've had some success getting a suitable transformer in terms of size and power, then adding my own windings on top of the primary to get the voltages I need. Easier with lower voltages. I think there are a few places that will custom wind, so a bad transformer isn't the end of the world if you value the piece.
hi all yes it still gets hot with the secondary fuses removed - burning hot! its definitely shorted the yellow wires get 0 volts. i'll see if i can find a suitable replacement
Very strange as it seems to be a secondary short at the leads of the yellow wires, but would expect the fuse to pop, of the primary to open. Agree that its bad.
We will never know what abuse that transformer has been through, a short on the yellow 30Vac low current winding before the fuses?
