Sansui AU-517 and Project TurnTable humming noise
Nothing to do with your current issue but having that much exposed conductor on your speaker wires is just begging for a problem. Anything metal comes across those and the magic smoke will be released.
Safe to assume it is the TT that is the problem now, I think.
You've still not told us if the hum gets worse when you unplug just the ground from the amplifier.
So to be clear, with the turntable RCAs plugged into Phono 1, the amplifier turned on and set to Phono 1, and the ground spade secured to the ground lug of the amp, take note of the volume of the hum. Now, please disconnect just the ground spade from the amplifier. Does the hum get louder or stay exactly the same?
Humm/zzzz noise gets louder when I disconnect the ground wire. I do NOT have the humming/zzz sound when playing cd. I've tried it with Phone 1 and Phone 2.
Ok, that suggests that there is not a break in your ground wire. Looking at the RCA cables you're using, there doesn't seem to be much shielding and they look longer than needed. Do you have any shorter cables with better shielding?
Yes, with the RCA plugged in to either Phono1 or Phono2, when I groundwire is plugged in, hummm/zzz noise is slightly less but I can clearly hear it when I'm playing record. If I undo the groundwire, the noise gets much louder.
I do not hear the sound when playing CD.
The RCA cable is NOT detachable from the turntable ... the turn table doesn't have RCA cable holes... the wire goes from back of the TT and only the other end has the rca plug ... if that make sense to u ...
The RCA cable is directly connected to the TT... i can't remove that to have a shorter cable :(
Ok, it looks like you've got a Project Essential II turntable. Check out this video:
Before you do what the guy in the video does. Try plugging your turntable into an outlet other than the one that the Sansui is plugged into. Sometimes that helps with hum/buzz.
Will try.. i did NOT do that b4. Let me see.
