Finally, replaced all of the output transistors wiring and Sil-pads (upgraded to 18 gauge wire as were the connectors) on the amp. Before powering up the amp, I adjusted all the VR's per the SM.
Initially, the amp was started up using the DBT, it came out of protect and the bulb brightened and dimmed out.
Removed the DBT, and connected two DMM's for the bias adjustment. Raised the AC input voltage using a Variac and monitored the DMM's, they were reading 2-3 millivolts when the AC input voltage equaled 120v AC and the amp came out of protect. After the amp warmed up for several minutes, both channels were adjusted to 23 millivolts.
Connected the two DMM's to the Left and Right Speaker outputs for the DC offset adjustment, found 1 to 1.5 volts DC on the DMM's. Before I could make any adjustments, the amp went into protect and it was turned off.
Disconnected, both left and right channel output amps, and was able to bring the amp up and out of protection using the DBT. The bulb barely brightened then dimmed and all DC rail voltages measured normally.
The right channel output amp passed the DBT and the amp came out of protection. The left channel output amp failed the test.
Currently, checking the left channel output amp on the bench and have found no problems yet.
Any thoughts or ideas on how to proceed are most welcome.
Thanks, Bob
