As Found Condition: The AU-719 is in protection when both the L channel or R channel Driver Boards are installed and there is a positive DC voltage on the output of both Driver Boards. With either Driver Board is installed by itself the protection issue persists. When both Driver Boards are out of service the amp comes out of protection and all of the amps DC bus voltages check normal.
TR12 is biased off by this condition and all of the voltages around the input dual N Channel JFET don't agree with the schematic. Checked all of the individual components on both Driver Boards in and out of the circuit and they all checked within specification.
Has anyone experienced this condition, and if so, can you please point in the right direction toward a solution?
Thank you,
Bob
Thank you,
Bob
