To remove the rod , you'll have to remove faceplate. Then it comes off along with the pushbutton.
Make sure you order all new trimmers. Also bear in mind there are a couple hidden in the front pcb behind the faceplate ,they are preamp dc offset.
The volume knob is hard fixed , but if you insist it will slide off . Don't be afraid of it.
Good luck. It's not a heavy work amp to recap . Actually it's pretty straight forward.
Thanks for the tips! I’ll try remove the plate tonight…the knob was very stuck on but will give it another go. So far looks all original inside and clean
