Based on my success with my recent BA3000 project, I decided to get back to my AU20000. I am not getting +35/-35 on the f-2508 board. I have good rail voltages and the +/- 65 is spot on. The schematic has little or no test point voltages for the 35 volt section. I have been through this board multiple times and still no 35 volts output. Waiting on a couple ceramic resistors for r14 and R11 which are off board and 220 ohm 20 watts on the unit currently. I ordered 220ohm 25 watt which are the same size. This board is essentially the same as the BA3000 and I used exactly the same approach with no success. I have no shorts and the dim bulb is a good result.
Any test point voltages would be very helpful. I was able to find a thread on specifically the +35/-35 section of f-2508 which wanders around a bit but goes through the basic steps of trouble shooting. https://audiokarma.org/forums/index.php?threads/sansuii-ba-3000-problems.785942/page-4 …pages 4-9
I also found a recent very detailed walkthrough of an AU20000 restoration which is fantastic with detailed images and parts lists for each board. https://alexandrugroza.ro/vintageaudio/amplifier/sansui_au-20000/index.html
